Hello All,
I’m just started into HA and everything worked very well.
Just wanted to connect everything nice and backuped the system, give it a shutdown, connected everything the way I want (didn’t change the USB connection of the Conbee and P1 meter).
Power on… and got an error in Zigbee Home Automation. It is not starting. Did a reboot/power cycle/restored the back-up. Still the same result.
Conbee firmware is up-to-date. Did also uninstall Zigbee Home Automation and tried to reinstall in. Same result. Last thing was to update to HA 9.3 (before 9.2). Also no effect.
What did I do wrong?
Thank you in advance.
The first message of the event viewer:
Logger: homeassistant.components.zha.core.gateway
Source: components/zha/core/gateway.py:172
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 20:16:44 (3 occurrences)
Last logged: 20:16:51
Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 1 of 3)
Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 2 of 3)
Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 3 of 3)
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 172, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 144, in new
await app.startup(auto_form=auto_form)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 125, in startup
await self.initialize(auto_form=auto_form)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 110, in initialize
await self.permit(0)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 929, in permit
await zigpy.zdo.broadcast(
File "/usr/local/lib/python3.10/site-packages/zigpy/device.py", line 518, in broadcast
return await app.broadcast(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 744, in broadcast
await self.send_packet(
File "/usr/local/lib/python3.10/site-packages/zigpy_deconz/zigbee/application.py", line 419, in send_packet
raise zigpy.exceptions.DeliveryError(
zigpy.exceptions.DeliveryError: Failed to deliver packet: <TXStatus.MAC_CHANNEL_ACCESS_FAILURE: 225>
