Hi, at the outset I’m sorry, my questions are probably stupid, but I’m a newbie at the beginning of the road. I have Home Assistant Blue edition (odroid n2 +) and Conbee II. I managed to set up Zigbee2MQTT and add Tuya TS0201, however after some time it stopped updating temperature and humidity. I started fumbling around and updated my Zigbee2MQTT. Unfortunately an error has occurred:
Zigbee2MQTT: error 2021-02-11 19:56:05: Error while starting zigbee-herdsman
Zigbee2MQTT: error 2021-02-11 19:56:05: Failed to start zigbee
Zigbee2MQTT: error 2021-02-11 19:56:05: Exiting …
Zigbee2MQTT: error 2021-02-11 19:56:05: Error: Error while opening serialport ‘Error: Error: No such file or directory, cannot open / dev / ttyACM0’
So I went into the configuration (hardware) to check the Conbee II port and noticed that the ports information is different than before. It was something like this at the beginning of info:
series:
- / dev / ttyACM0
- / dev / ttyS0
- / dev / ttyS1
- / dev / ttyS2
- / dev / ttyS3
Now the information in the hardware starts like this:
devices:- name: ttyS0
sysfs: / sys / devices / platform / serial8250 / tty / ttyS0
dev_path: / dev / ttyS0
subsystem: tty
by_id: null
attributes:
DEVNAME: / dev / ttyS0
DEVPATH: / devices / platform / serial8250 / tty / ttyS0
MAJOR: ‘4’
MINOR: ‘64’
SUBSYSTEM: tty - name: ttyS1
sysfs: / sys / devices / platform / serial8250 / tty / ttyS1
dev_path: / dev / ttyS1
subsystem: tty
by_id: null
attributes:
DEVNAME: / dev / ttyS1
DEVPATH: / devices / platform / serial8250 / tty / ttyS1
MAJOR: ‘4’
MINOR: ‘65’
SUBSYSTEM: tty
…etc.
However, ttyACM0 is missing as evidenced by the Zigbee2MQTT logs. I have updated Conbee II to deCONZ_ConBeeII_0x26680700.bin.GCF. However, I still don’t see Conbee II. Meanwhile, I also updated the Core and Home Assistant OS. Below is the info about the current state:
- name: ttyS0
System Health
Version core-2021.2.3
Installation Type Home Assistant OS
Development false
Supervisor true
Docker true
Virtual Environment false
Python Version 3.8.7
Operating System Family Linux
Operating System Version 5.9.16
CPU Architecture aarch64
Timezone Europe / Warsaw
Host Operating System Home Assistant OS 5.11
Update Channel stable
Supervisor Version supervisor-2021.02.6
Docker Version 19.03.13
Disk Total 113.9 GB
Disk Used 6.2 GB
Healthy true
Supported true
Board odroid-n2
Supervisor API approx
API version ok
Installed Add-ons Mosquitto broker (5.1), Zigbee2mqtt (1.17.1), File editor (5.2.0), Samba share (9.3.0), Node-RED (8.0.1)
Can you help me somehow?
