everything seems to work fine…is this a bug or normal?
Uh I’m still not sure what is going on. Would a bad mesh or a different device causing havoc make the conbee go offline for no reason? What would be the best route to take here? is this due to a defective conbee ii?
Did you solve the problem ?
I think so… switched to using an active usb extension cable. although it may not be because it is an active cable. the old cable could of just been defective in some way or they just used low quality materials.
