Hi, I have decided to give Zigbee a try, so bought a Conbee II (hoping for better compatibility than the cheaper Tuya or Sonoff gateways) and some Sonoff zigbee devices for testing
However I am having an issue:
My Home Assistant installation is running inside a docker container on a virtual machine in Proxmox. I have passed trough the Conbee USB device to the VM and is showing up in lsusb inside the VM, Phoscon app (via docker-deconz) is working, I can see the gateway, but it refuses to connect to any Zigbee device. When I moved the Conbee to my windows pc i was able to pair the devices without any problem, even adding them to home assistant.
Do you guys using home assistant inside VM (hass.io users ?) experience this?
i am not sure what to you mean by supervisor. i understand supervisor in home assistant context as Home Assistant OS.
this is my docker-compose for deconz, maybe the non-standard ports are causing the issue ? (due to 30+ docker containers i am running out of standard ports)
Supervisor is available for Home Assistant OS and Home Assistant Supervised. You are running Home Assistant Container. I was just confused because you wrote about hass.io.
Can you please show a screenshot of the gateway page in Phoscon.
well i don’t know how, but when putting back the gateway into my server the devices suddenly paired OK. even backup works, which resulted in an error before.
yesterday i was trying it for an hour in different usb ports without any luck… will see if it will hold or not.
Can it bee that all the devices you try to pair, are still paired with the old network. To pair a device with a new Network, you have to reset the devices into pairing mode.
