Hoping someone can help (I’ve also got an issue raised with deconz but don’t really think it’s their issue).
I’m running proxmox 5.4 on an intel NUC. On top of that I have a VM (not an LCX container) running Ubuntu 18.04 server. On that, I’m running docker and with a hass and a couple of other things. All good so far.
I’ve got a Conbee-II plugged in, and I’ve passed it through to the VM. In the VM O/S the stick is showing up when I run lsusb, I can see entries in dmesg, but it’s not in /dev (assuming it should be /dev/ttyACM0 or /dev/ttyUSB0) - I have no other USB devices.
lsusb output
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 1cf1:0030 Dresden Elektronik
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
dmesg output
[ 9.464250] usb 3-1: new full-speed USB device number 2 using uhci_hcd
[ 9.922364] usb 3-1: New USB device found, idVendor=1cf1, idProduct=0030
[ 9.922926] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.923596] usb 3-1: Product: ConBee II
[ 9.923941] usb 3-1: Manufacturer: dresden elektronik ingenieurtechnik GmbH
[ 9.924588] usb 3-1: SerialNumber: DE1963697
So, 1st question is has anyone got a Conbee working in a proxmox VM?
2nd question did it “just work” or did you need to do something?
3rd question any ideas what else I can try?
thanks in advance
