RP3, Hassio, HA, ConBee and IKEA Trådfri Driver, has anyone tested this?
Yeah I have it working ok.
Thanks for the quick answer, just sitting and converting to hassio!
But how do I connect Conbee2 to a LED-driver?
I’ve connected alrijdy an ikea remote with the LED-driver, but can’t connect the conbee2 with this driver.
same issue, how did you connect the driver to conbee please?
In zigbee, only one device gets to be the controller. Once you paired the bulbs, led-driver, remotes, outlets etc they formed a network.
You need to reset the bulb, or in this case the led-driver so it can be added to a new network. Which is not always easy > when migrating to conbee I had one Innr light bulb that I could reset, but never pair again. Fortunately when I contacted their support and explained, they sent me over a replacement within a few days
Pairing again is best done as close as possible to your new ‘controller’ and I would recommend not doing them all at once (that’s what I first tried)
How do you Connect the driver to zigbee in home assistant without Ikea hub?
Try the instructions on Setup Ikea Trådfri with deCONZ in Home Assistant – Lucas TechBlog to pair a tradfri driver with deconz.
The driver has a reset hole. Use a paperclip to reset the driver.
