Good morning,
A few days ago I freshly installed HA on a Raspberry Pi4 8GB with SSD because my Pi3 died on me.
After restoring everything the way it was my Zigbee network didn’t seem to work, so I tried re-pairing my devices without any luck. I tried another Conbee2 I had laying around, but that also didn’t work.
I’m running HassOS 5.3 with HA 116.2. My DeCONZ config isn’t different from my Pi3:
device: >-
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2229282-if00
I’m using an USB extension cord between my Pi and Conbee as recommended by Dresden. The only thing I can think of is a power problem, my SSD gave a lot of UAS errors so I setted up a quirk for that, but I read somewhere that a power problem also can cause UAS errors. I’m using the 3A power supply from RPI.
I ordered a USB3.0 Y cable just to be sure, but maybe someone here has another suggestion?
Hope to hear from you!
Regards,
