Concatenate strings variables in script
I want to create a script where at different steps I would like to amend a given string variable so that I can send it at the end within a notification.
Let’s say I define a first variable :
  • variables:
    mystring: line 1
Then later I want to add some text to the variable mastering.
I create a second variable string-to-add:
  • variables:
    string_to_add: line 2
Then what is the proper syntax to concatenate the variable string_to_add to the initial variable mystring ?
For example the following syntax does not seem to work:
  • variables:
    newstring2: {{mystring}} + {{string-to-add}}
Eric
How about this?
newstring2: {{ mystring + string-to-add }}
It is preferable to use ~ rather than + for string concatenation.
Thanks for replies. I have tested these 2 options, but what is weird is that in both cases after saving, the YAML editor transformed the line in:
newstring2:
    "[object Object]": null
SO it seems it does like the syntax.
I am editing in the web interface using Firefox.
Quote your single line templates:
newstring2: "{{ mystring ~ string-to-add }}"
I finally got it !
I had to put the expression {{ mystring ~ string_to_add }} between double quotes:
variables:
newstring2: “{{ mystring ~ string_to_add }}”
Is OK. BTW, both + and ~ seem to work.
Anyhow, thx for the initial tip.
Eric
