Concord232 data going to home assistant?
Greets all,
What information is actually expected to be exchanged between concord232 and a concord 4 panel? It looks like the only exchange home assistant is receiving/sending is binary_sensors (status) and arm/disarm (status and command).
Should home assistant also be able to receive info when the alarm actually triggers when it’s armed? Or on a smoke alarm at any time?
Second question:
How do most folks use the points from Concord232? Do most folks do a lot of automations? or do they interface into something like HACS alarmo? Or both? Or some other approach entirely?
Thanks in advance!
Background:
I have successfully installed and am getting data exchange between my concord4 system and concord232 using the code and guidelines found at
concord232
(with much thanks!)
And appears to be working as expected, except for the questions above.
