Team
I have this weird issue on concurrency.
I’ve developed a component to send and receive the status of the videoprojector, here is the code: msavazzi/homeassistant-jvc-dila (github.com)
Based on the Home Assistant TCP component it does have both a binary sensor as well as a sensor.
If I configure only one of the two it works perfectly, no errors.
if I configure both of them:
2022-12-29 18:24:57.235 WARNING (SyncWorker_7) [custom_components.jvc_dila.common] 1 - PJ_OK
2022-12-29 18:24:58.440 WARNING (SyncWorker_7) [custom_components.jvc_dila.common] 2 - PJACK
2022-12-29 18:24:59.074 ERROR (SyncWorker_4) [custom_components.jvc_dila.common] 1 Unable to connect to 192.168.1.94 on port 20554: [Errno 111] Connection refused
2022-12-29 18:24:59.642 WARNING (SyncWorker_7) [custom_components.jvc_dila.common] 3 - (6) b'\x06\x89\x01PW\n'
2022-12-29 18:25:00.244 WARNING (SyncWorker_7) [custom_components.jvc_dila.common] 4 - b'@\x89\x01PW0\n'
2022-12-29 18:25:00.276 WARNING (SyncWorker_4) [custom_components.jvc_dila.common] 1 -
2022-12-29 18:25:00.277 WARNING (SyncWorker_4) [custom_components.jvc_dila.common] Unable to send PJREQ on port 192.168.1.94: 20554 error [Errno 32] Broken pipe
and either of the items gives an error (usually the BinarySensor).
The correct flow should be (as is scheduled to run every 10 sec):
2022-12-29 18:33:45.902 WARNING (SyncWorker_6) [custom_components.jvc_dila.common] 1 - PJ_OK
2022-12-29 18:33:47.105 WARNING (SyncWorker_6) [custom_components.jvc_dila.common] 2 - PJACK
2022-12-29 18:33:48.316 WARNING (SyncWorker_6) [custom_components.jvc_dila.common] 3 - (6) b'\x06\x89\x01PW\n'
2022-12-29 18:33:48.917 WARNING (SyncWorker_6) [custom_components.jvc_dila.common] 4 - b'@\x89\x01PW1\n'
2022-12-29 18:33:55.904 WARNING (SyncWorker_7) [custom_components.jvc_dila.common] 1 - PJ_OK
2022-12-29 18:33:57.106 WARNING (SyncWorker_7) [custom_components.jvc_dila.common] 2 - PJACK
2022-12-29 18:33:58.308 WARNING (SyncWorker_7) [custom_components.jvc_dila.common] 3 - (6) b'\x06\x89\x01PW\n'
2022-12-29 18:33:58.909 WARNING (SyncWorker_7) [custom_components.jvc_dila.common] 4 - b'@\x89\x01PW1\n'
it appears it does try to open two connections to the projector at the same time
here is the config.yaml:
- platform: jvc_dila
host: 192.168.1.94
port: 20554
scan_interval: 10
binary_sensor:
host: 192.168.1.94
port: 20554
scan_interval: 10
Any suggestion?
any way to define it “single”? or avoid concurrency? also why is being invoked twice when I configure both BinarySensor and Sensor?
