Hi everybody,
In Conditions it says that
Conditions can be used within a script or automation to prevent further execution. When a condition evaluates true, the script or automation will be executed. If any other value is returned, the script or automation stops executing.
However, I have an automation where a false condition inside a ‘choose’ action will not halt the execution of the automation. I wonder whether it is a documentation bug, an execution bug or (probably) a lack of understanding on my part.
I would appreciate the help.
Here is the automation:
- id: activar_precalentamiento_dormitorio_padres
alias: Activar Precalentamiento Dormitorio Padres
description: Precalentar antes de hora el dormitorio de padres cuando hace mucho frio
trace:
stored_traces: 12
triggers:
- trigger: time
at:
- entity_id: sensor.wiser_dormitorio_next_schedule_change
offset: "-00:30:00"
variables:
tiempo_precalentamiento: 30
- trigger: time
at:
offset: "-01:00:00"
variables:
tiempo_precalentamiento: 60
- trigger: time
at:
offset: "-01:30:00"
variables:
tiempo_precalentamiento: 90
- trigger: time
at:
offset: "-02:00:00"
variables:
tiempo_precalentamiento: 120
- trigger: time
at:
offset: "-02:30:00"
variables:
tiempo_precalentamiento: 150
actions:
- alias: "Fijamos resto de variables"
variables:
velocidad_cambio_temp_30_min: 0.7
temperatura_actual: "{{ state_attr('climate.wiser_dormitorio', 'current_temperature') }}"
temperatura_siguiente: "{{ state_attr('climate.wiser_dormitorio', 'next_schedule_temp') }}"
esta_precalentando: "{{ state_attr('climate.wiser_dormitorio', 'is_boosted') }}"
tiempo_escrito: {'30': 'media hora', '60': 'una hora', '90': 'hora y media', '120': 'dos horas', '150': 'dos horas y media'}
- alias: "Comprobamos que se cumplen las condiciones"
choose:
- alias: "Condiciones para el trigger P30"
conditions:
- condition: trigger
sequence:
- condition: and
conditions:
- alias: "Que la habitación no esté ya en precalentamiento"
condition: template
value_template: "{{ not esta_precalentando }}"
default:
- alias: "Condiciones para todos los triggers menos el P30"
condition: and
conditions:
- alias: "Que el diferencial de temperatura sea igual o mayor que que la velocidad de cambio de temperatura"
condition: template
value_template: "{{ (temperatura_siguiente - temperatura_actual) >= (velocidad_cambio_temp_30_min * tiempo_precalentamiento / 30) }}"
condition: template
- alias: "Precalentamos durante el tiempo establecido"
action: script.execute_wiser_boost
room: climate.wiser_dormitorio
boost_time: "{{ tiempo_precalentamiento }}"
temp_delta: "{{ (temperatura_siguiente - temperatura_actual) }}"
- alias: "Activamos el deshumidificador"
action: humidifier.turn_on
entity_id: humidifier.dormitorio_padres
- alias: "Notificamos al administrador del precalentamiento"
action: notify.mobile_app_javier_movil
message: "El Dormitorio de padres se precalentará durante {{ tiempo_escrito[tiempo_precalentamiento | string] }}"
title: Feira
and here is the trace
"trace": {
"last_step": "action/4",
"run_id": "5ef00819728520484010f5e1c325d915",
"state": "stopped",
"script_execution": "finished",
"timestamp": {
"start": "2024-11-23T18:30:00.000924+00:00",
"finish": "2024-11-23T18:30:02.270850+00:00"
"domain": "automation",
"item_id": "activar_precalentamiento_dormitorio_padres",
"trigger": "time set in sensor.wiser_dormitorio_next_schedule_change",
"trace": {
"trigger/2": [
"path": "trigger/2",
"timestamp": "2024-11-23T18:30:00.001041+00:00",
"changed_variables": {
"this": {
"entity_id": "automation.activar_precalentamiento_dormitorio_padres",
"state": "on",
"attributes": {
"id": "activar_precalentamiento_dormitorio_padres",
"last_triggered": "2024-11-23T18:00:00.000901+00:00",
"mode": "single",
"current": 0,
"friendly_name": "Activar Precalentamiento Dormitorio Padres"
"last_changed": "2024-11-23T00:23:04.727183+00:00",
"last_reported": "2024-11-23T18:00:03.453807+00:00",
"last_updated": "2024-11-23T18:00:03.453807+00:00",
"context": {
"id": "01JDD2WF80TTKEWY5JS99D72NA",
"parent_id": null,
"user_id": null
"trigger": {
"id": "P90",
"idx": "2",
"alias": null,
"platform": "time",
"now": "2024-11-23T19:30:00+01:00",
"description": "time set in sensor.wiser_dormitorio_next_schedule_change",
"entity_id": "sensor.wiser_dormitorio_next_schedule_change"
"tiempo_precalentamiento": 90
"action/0": [
"path": "action/0",
"timestamp": "2024-11-23T18:30:00.001424+00:00",
"context": {
"id": "01JDD4KD20AT8R1B7BWSPSZKZ3",
"parent_id": null,
"user_id": null
"velocidad_cambio_temp_30_min": 0.7,
"temperatura_actual": 20.1,
"temperatura_siguiente": 20,
"esta_precalentando": true,
"tiempo_escrito": {
"30": "media hora",
"60": "una hora",
"90": "hora y media",
"120": "dos horas",
"150": "dos horas y media"
"action/1": [
"path": "action/1",
"timestamp": "2024-11-23T18:30:00.001900+00:00",
"result": {
"choice": "default"
"action/1/choose/0": [
"path": "action/1/choose/0",
"timestamp": "2024-11-23T18:30:00.001976+00:00",
"result": {
"result": false
"action/1/choose/0/conditions/0": [
"path": "action/1/choose/0/conditions/0",
"timestamp": "2024-11-23T18:30:00.002007+00:00",
"result": {
"result": false
"action/1/default/0": [
"path": "action/1/default/0",
"timestamp": "2024-11-23T18:30:00.002163+00:00",
"result": {
"result": false
"action/1/default/0/conditions/0": [
"path": "action/1/default/0/conditions/0",
"timestamp": "2024-11-23T18:30:00.002309+00:00",
"result": {
"result": false,
"entities": []
"action/2": [
"path": "action/2",
"timestamp": "2024-11-23T18:30:00.002555+00:00",
"child_id": {
"domain": "script",
"item_id": "execute_wiser_boost",
"run_id": "4cdd7b2b210bf2585ce2593f1bf741cd"
"result": {
"params": {
"domain": "script",
"service": "execute_wiser_boost",
"service_data": {
"room": "climate.wiser_dormitorio",
"boost_time": 90,
"temp_delta": -0.10000000000000142
"target": {}
"running_script": true
"action/3": [
"path": "action/3",
"timestamp": "2024-11-23T18:30:01.198699+00:00",
"result": {
"params": {
"domain": "humidifier",
"service": "turn_on",
"service_data": {
"entity_id": "humidifier.dormitorio_padres"
"target": {}
"running_script": false
"action/4": [
"path": "action/4",
"timestamp": "2024-11-23T18:30:01.199308+00:00",
"result": {
"params": {
"domain": "notify",
"service": "mobile_app_javier_movil",
"service_data": {
"message": "El Dormitorio de padres se precalentará durante hora y media",
"title": "Feira"
"target": {}
"config": {
"alias": "Activar Precalentamiento Dormitorio Padres",
"description": "Precalentar antes de hora el dormitorio de padres cuando hace mucho frio",
"trace": {
"stored_traces": 12
"triggers": [
"trigger": "time",
"at": [
"entity_id": "sensor.wiser_dormitorio_next_schedule_change",
"offset": "-00:30:00"
"id": "P30",
"variables": {
"tiempo_precalentamiento": 30
"trigger": "time",
"at": [
"offset": "-01:00:00"
"id": "P60",
"variables": {
"tiempo_precalentamiento": 60
"trigger": "time",
"at": [
"offset": "-01:30:00"
"id": "P90",
"variables": {
"trigger": "time",
"at": [
"offset": "-02:00:00"
"id": "P120",
"variables": {
"tiempo_precalentamiento": 120
"trigger": "time",
"at": [
"offset": "-02:30:00"
"id": "P150",
"variables": {
"tiempo_precalentamiento": 150
"actions": [
"alias": "Fijamos resto de variables",
"variables": {
"temperatura_actual": "{{ state_attr('climate.wiser_dormitorio', 'current_temperature') }}",
"temperatura_siguiente": "{{ state_attr('climate.wiser_dormitorio', 'next_schedule_temp') }}",
"esta_precalentando": "{{ state_attr('climate.wiser_dormitorio', 'is_boosted') }}",
"tiempo_escrito": {
"30": "media hora",
"60": "una hora",
"120": "dos horas",
"alias": "Comprobamos que se cumplen las condiciones",
"choose": [
"alias": "Condiciones para el trigger P30",
"conditions": [
"condition": "trigger",
"id": "P30"
"sequence": [
"condition": "and",
"conditions": [
"alias": "Que la habitación no esté ya en precalentamiento",
"condition": "template",
"value_template": "{{ not esta_precalentando }}"
"default": [
"alias": "Condiciones para todos los triggers menos el P30",
"condition": "and",
"conditions": [
"alias": "Que el diferencial de temperatura sea igual o mayor que que la velocidad de cambio de temperatura",
"value_template": "{{ (temperatura_siguiente - temperatura_actual) >= (velocidad_cambio_temp_30_min * tiempo_precalentamiento / 30) }}"
"alias": "Precalentamos durante el tirmpo establecido",
"action": "script.execute_wiser_boost",
"data": {
"boost_time": "{{ tiempo_precalentamiento }}",
"temp_delta": "{{ (temperatura_siguiente - temperatura_actual) }}"
"alias": "Activamos el deshumidificador",
"action": "humidifier.turn_on",
"data": {
"alias": "Notificamos al administrador del precalentamiento",
"action": "notify.mobile_app_javier_movil",
"data": {
"message": "El Dormitorio de padres se precalentará durante {{ tiempo_escrito[tiempo_precalentamiento | string] }}",
"title": "Feira"
"blueprint_inputs": null,
"context": {
"parent_id": null,
"user_id": null
"logbookEntries": [
"name": "Activar Precalentamiento Dormitorio Padres",
"message": "triggered by time set in sensor.wiser_dormitorio_next_schedule_change",
"source": "time set in sensor.wiser_dormitorio_next_schedule_change",
"context_id": "01JDD4KD20AT8R1B7BWSPSZKZ3",
"when": 1732386600.0011194
"name": "Wiser Boosts",
"message": "started",
"entity_id": "script.execute_wiser_boost",
"domain": "script",
"when": 1732386600.0029066,
"context_event_type": "automation_triggered",
"context_domain": "automation",
"context_name": "Activar Precalentamiento Dormitorio Padres",
"context_message": "triggered by time set in sensor.wiser_dormitorio_next_schedule_change",
"context_source": "time set in sensor.wiser_dormitorio_next_schedule_change",
"context_entity_id": "automation.activar_precalentamiento_dormitorio_padres"
"state": "on",
"icon": "mdi:script",
"when": 1732386600.0030718,
"state": "off",
"when": 1732386601.1979072,
Javier.
