I have a bunch of Xiaomi Aqara temperatur sensors connected via deconz to Hassio.
Is it possible to change the icon color of battery_entity when it goes low.
The icons are in ’ Horizontal Stack Card’
Appreciate to know how to proceed …
There’s a custom card for that.
EDIT: don’t use this card. It has not been maintained. Use the state-card linked below.
Personally I created a bunch of template sensors to change the icon. I don’t use colors, but you could modify your own accordingly (likely using entity_picture_template vs. icon_template):
battery_ms_thinkpad:
friendly_name: ThinkPad Battery
unit_of_measurement: '%'
value_template: >-
{{ states('sensor.thinkpad_battery') }}
icon_template: >-
{% if is_state('binary_sensor.thinkpad_battery_trend', 'on') %}
{% set battery_charge = 'charging-' %}
{% endif %}
{% set battery_level = states('sensor.thinkpad_battery')|int %}
{% set battery_round = (battery_level|int / 10)|int * 10 %}
{% if battery_level == 'unknown' %}
mdi:battery-unknown
{% else %}
{% if battery_round >= 100 %}
{% if battery_charge == 'charging-' %}
mdi:battery-charging-100
{% else %}
mdi:battery
{% endif %}
{% elif battery_round > 9 %}
mdi:battery-{{battery_charge}}{{ battery_round }}
{% else %}
mdi:battery-{{battery_charge}}outline
{% endif %}
{% endif %}
For me, different devices have different ways to show if a device is charging, my phones (tracked via Google Maps) are a bit different and don’t use the ‘trend’, but show w/in the device_tracker entity itself:
{% if is_state_attr('device_tracker.google_maps_xxx', 'battery_charging', true) %}
{% endif %}
Thanks guys … I will test it and give you feedback … have a nice day
Hi, if you have HACS installed, I sugest you to try “Battery State Card” plugin…
It has already been suggested.
or use the gauge card?
The gauge cards are to big …
Sorry I did not noticed it
My bad…
OK … I installed HACS and all went OK but it says …
When installed, this will be located in ‘/config/custom_components/hacs’, you still need to add it to your ‘configuration.yaml’ file.
How do I add it to ‘configuration.yaml’?
There should be a button up the top of the plugin’s page to add it for you. Sorry that’s the resource for plugins.
Follow the instructions here:
There is nothing in the instruction about this … got this when clicking on HACS in left panel
Do I just add
hacs:
without options in configuration.yaml?
Sorry … I missed it totally.
Thanks for reminding me to study documentation more carefully.
How come I don’t see the HACS store in Add-On store …
I am trying to get the ‘Battery State Card’ but can’t find it …
It’s not in the addon store.
Look for it in the left hand menu bar:
Thanks again … I am learning more and more …
Actually what was recommended was the battery-entity plugin.
The battery-state-card plugin is different.
Got a link for it?
I can’t find it.
It’s also in HACS.
I literally just installed it minutes ago.
