What I’d like is to have an automation that runs a script when the front door is opened, but only once after my status is changed to ‘home’, But I can’t figure out how to do it. Is it possible to add “for” in the conditions - to say for example “state: home, for: <5 minutes”? Or is there some better way to do this? I know I could have another automation trigger an input boolean when I arrive/leave home, and have this automation look at the boolean as a condition, but I was just hoping for something neater. Thanks!
With the information you’ve given, the following should work. If you don’t mind me asking what the rest of the automation is? There might be a better way.
condition:
condition: template
value_template: >
{% set current = as_timestamp(now()) %}
{% set device = states.device_tracker.name %}
{% set stamp = as_timestamp(device.last_changed) %}
{{ device.state == 'home' and current - stamp < 300 }}
It’s absolutely ridiculous, but basically when I come home from work I want the Seinfeld theme to play when I open the door. Any help on how to achieve this is much appreciated, as I obviously don’t want that to happen every time the door is opened!
I have a set of announcements that play. I might replace them with an applause track for a couple of days as a moral booster.
I use an input boolean that is set when I go to bed or when I arm the house alarm.
It is cleared when the announcement is played (triggered by a PIR) but the condition posted by @walrus_parka is a good one too.
