Hi guys,
I have esp8266 devices with relays and esphomelib firmware.
In my setup when I press a button switch on the philips hue lights and skip the integrate relay.
I wanted to do this because it’s more beautiful as an effect.
The only problem is that if the home assistant is not active I cannot switch on the lights in the house …
how can I create a condition where, if the esp8266 device does not detect home assistant server and when the button is pressed, the relays are activated or deactivated?
This is my configuration, thanks
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: ‘*******’
password: ‘********’
manual_ip:
static_ip: *********
gateway: *********
subnet: 255.255.255.0
domain: .corridoio.local
Enable logging
logger:
Enable Home Assistant API
api:
ota:
web_server:
port: 80
- platform: wifi_signal
update_interval: 60s
binary_sensor:
platform: gpio
device_class: motion
pin:
number: D4
on_press:
if:
condition:
- switch.is_on: correle
then:
- homeassistant.service:
service: light.turn_on
entity_id: light.corridoio_2
else:
- switch.turn_on: correle
- delay: 500ms
entity_id: light.corridoio_2 -
platform: template
name: “Corridoio Pir Time”
lambda: ‘return id(corpir).state;’
filters:- delayed_off: 30s
on_release: - homeassistant.service:
service: light.turn_off
- delayed_off: 30s
platform: gpio
pin:
number: TX
inverted: True
on_multi_click:- timing:
- ON for at most 1s
- OFF for at most 1s
- ON for at most 1s
- OFF for at least 0.5s
then: - homeassistant.service:
service: light.toggle
entity_id: light.corridoio_2 - logger.log: “2Click”
- timing:
- ON for 1s to 2s
entity_id: light.sala - homeassistant.service:
entity_id: light.cucina - homeassistant.service:
service: switch.turn_off
entity_id: switch.led_cucina_rele - logger.log: “LongPress”
- timing:
- ON for at most 1s
then:
if:
condition:- switch.is_on: salarele
entity_id: light.sala - logger.log: “Click”
else: - switch.turn_on: salarele
- timing:
platform: gpio
pin:
number: RX
inverted: True
- ON for at most 1s
- ON for at most 1s
then: - logger.log: “2Click”
service: switch.toggle
- timing:
- ON for 1s to 2s
service: switch.turn_on
entity_id: switch.led_cucina - logger.log: “LongPress”
- timing:
- ON for at most 1s
entity_id: light.cucina - logger.log: “Click”
- timing:
switch:
platform: gpio
pin:
number: D5
mode: OUTPUT -
platform: gpio
pin:
number: D7
mode: OUTPUT
