Condition in automation to limit execution if entity was triggered by the same automation
Hi, I’m trying to control my kitchen fan (which is also controlled by other automations) so that this automation will only turn off the switch if said switch (switch.kjokken_vifte) was triggered by this automation last time.
This is my automation this far based on trigger context, however is failing to turn of the switch
alias: "Kjøkken: Kjøre vifte for bedre klima"
description: ""
triggers:
  - trigger: time_pattern
    minutes: "*"
    alias: Sjekk om vifte er av
  - trigger: state
    entity_id:
      - switch.kjokken_vifte
    to: "on"
    for:
      hours: 0
      minutes: 0
      seconds: 10
    alias: Vifte er på
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - fan_on
          - alias: Utløst av denne automasjonen?
            condition: template
            value_template: >-
              {{ trigger.to_state.context.id ==
              states.automation.kjokken_kjore_vifte_for_bedre_klima.context.id
            enabled: true
        sequence:
          - action: switch.turn_off
            metadata: {}
            data: {}
              entity_id: switch.kjokken_vifte
        alias: Skru av vifte
      - conditions:
            id:
              - fan_off
          - condition: time
            after: "07:00:00"
            before: "21:30:00"
          - condition: state
            state: "off"
            for:
              hours: 0
              minutes: 0
              seconds: 1
          - condition: numeric_state
            entity_id: zone.home
            above: 0
        sequence:
          - action: switch.turn_on
            metadata: {}
            data: {}
        alias: Skru på vifte
mode: single
In all essence it this condition I’m failing to complete correctly
            condition: template
            value_template: >-
And by the looks of it, HASS does know who triggered the switch last time so this should be possible I guess?
However the condition is not becoming true so I must be doing something wrong here?
Seems I found my solution
this.context.id == trigger.to_state.context.id
