jarrah
(jarrah)
July 8, 2022, 9:34am
1
Is there a way to program a condition to be true only when something like the following occurs please?
- condition: numeric_state
entity_id: sensor.plug_zigbee13_power
above: 10
for: "00:05:00"
Numeric state doesn’t support “for”, and the “state” condition doesn’t support “above” or “below”.
I can then only assume this should be done via a template, but I can’t figure out how to integrate the “above 10 watts for longer than 5 mins” part of the code. Tried searching the forums and google but had no luck so far.
- condition: template
value_template: >
{{ (states('sensor.plug_zigbee16_energy') | float > 10) }}
The general plan is for it to look like the yaml below. The reason behind this is I’d like an automation that triggers when the tumble dryer has finished based on energy usage. However when the dryer finishes, it rotates the drum every one minute to stop the clothes creasing which keeps triggering the automation below. I therefore need a condition that checks if the power has been over 10W for at least the past 5 mins.
- platform: state
to: '0'
for: "00:00:20"
condition:
# power has been over 10W for more than 5 mins
above: 10
for: "00:05:00"
Hellis81
(Hellis81)
July 8, 2022, 9:38am
2
I believe you should do it the other way around.
So use above 10 watt for 5 minutes as the trigger, and set a boolean dryer to on.
Then the next automation your automation above but the condition is that the boolean dryer is on.
Switch it to off and do the rest of the actions.
without checking the code logic, you can create a binary_sensor with a delay (on or off) to change state based on your preferences.
- unique_id: driveway_buiten_motion_sensor_timed
name: Driveway buiten motion sensor timed
state: >
{{is_state('binary_sensor.driveway_buiten_sensor_motion','on')}}
delay_off:
minutes: 2
or use even a template for the delay:
- unique_id: parking_trash_buiten_sensor_motion_timed
name: Parking trash buiten motion sensor timed
state: >
{{is_state('binary_sensor.parking_trash_buiten_sensor_motion','on')}}
delay_off: >
{{states('input_number.presence_timer')|int}}
device_class: motion
You can then use that binary as trigger.
Hellis is right, you should check your logic. because when you say
is the definition of a trigger (occur) and not condition. Maybe it’s not meant like that, just saying you need to sort your triggers (a momentary state change ) and conditions (a state at that time of trigger)
Hellis81
(Hellis81)
July 8, 2022, 11:55am
4
I was thinking something like this:
- platform: numeric_state
for:
minutes: 5
above: '10'
- platform: state
to: '0'
for:
seconds: 20
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
data: {}
entity_id: input_boolean.dryer
- conditions:
- condition: state
state: 'on'
sequence:
- service: input_boolean.turn_off
data: {}
- service: tts.cloud_say
entity_id: media_player.player
message: Dryer is done.
default: []
jarrah
(jarrah)
July 8, 2022, 12:14pm
5
aha, great idea, thanks!
I’ve set my automations like this for now and will see how it works out:
- alias: tumble_started
above: 10
for: "00:00:30"
- service: var.set
entity_id:
- var.tumble_started
value_template: >
{{ states('sensor.plug_zigbee13_energy') }}
entity_id:
- input_boolean.tumble_on
- service: notify.signal_justme
message: 'Tumble started'
- alias: tumble_finished_boolean
- platform: state
to: '0'
for: "00:00:20"
entity_id:
- platform: state
to: '0'
for: "00:00:45"
condition:
- condition: state
entity_id: input_boolean.tumble_on
state: 'off'
- service: var.update
entity_id: var.tumble_energy_difference
- delay:
seconds: 1
entity_id: var.tumble_cost
message: "Tumble finsihed. Cost is £{{ states('var.tumble_cost') }}."
Just for reference, this is the power usage graph that I’m working with:
jarrah
(jarrah)
July 8, 2022, 12:26pm
6
I like how you’ve combined the triggers. I’ll re-work mine to use the same method. Thank you!
jarrah
(jarrah)
July 12, 2022, 8:06pm
7
I like this solution too, thank you @Mariusthvdb !
Here is the result of combining both your suggestions:
automation:
- alias: tumble_automation
- platform: state
entity_id: binary_sensor.tumble_on_off
to: 'on'
for: "00:00:30"
- platform: state
to: 'off'
- choose:
- conditions:
sequence:
- service: var.set
entity_id:
value_template: >
- conditions:
sequence:
- delay:
seconds: 1
- service: notify.signal_ha
template:
binary_sensor:
- name: tumble_on_off
delay_off:
seconds: 25
state: "{{ states('sensor.plug_zigbee13_power') | float(0) > 10.0 }}"
you now have a double delay?
One in the template binary_sensor, and one in the trigger (for: “00:00:30”) ?
jarrah
(jarrah)
July 12, 2022, 8:57pm
9
I may be wrong in my understanding, but I thought the binary_sensor delay is for on → off, and the trigger delay is for off → on?
I haven’t been able to test this in anger yet (waiting for wife to wash something… )
Hellis81
(Hellis81)
July 12, 2022, 9:00pm
10
You can just set the state of the entity to simulate the washing.
Right. Missed that … sorry
maxnomo
November 26, 2024, 4:30pm
12
Hi, i have the demand for a powerswitch to be turned on (solar heating pump) if temp-roof is above the temperature of temp-tank. Right now i have the following configuration, which does NOT consider that this condition should last minimum some 5 minutes:
unit_of_measurement: "°C"
icon: 'mdi:delta'
update_interval: 10s
accuracy_decimals: 2
lambda: |-
return id(thsol_dach_adc1_0).state - id(thsol_unten_adc1_1).state ;
filters:
- offset: 0
- sliding_window_moving_average:
window_size: 6 # 60 s
send_every: 1 # 60 s
on_value_range:
- below: 2.0
then:
- script.execute: thsol_off
- above: 5.0
then:
- script.execute: thsol_on
then 2 scripts are activated to switch on resp. to switch off a GPIO-pin
# Scripts zum Schalten der Thermosolarpumpe
script:
- id: thsol_on
then:
- lambda: |-
if ( ((id(td28).state) < 80.0) )
id(gpio02).turn_on();
- id: thsol_off
then:
- lambda: |-
id(gpio02).turn_off() ;
So how to include a time delay in this construction ???
I was somehow inspired from above posts, but could not get the right final ideas. Any help is welcome…
