Condition on a state change
Hi guys, i didnt find how to add this condition.
I want to verify if the switch of my humidifier has been turn off in the last 10 min dont execute the automatisation.
I think i need to use a state_chage but didnt understand the doc about it.
alias: Humidifier On
description: ""
  - platform: numeric_state
    entity_id: sensor.thermometre_salon_humidity
    below: sensor.desired_humidity_min
condition: []
  - action: switch.turn_on
      entity_id: switch.prise_double_humidificateur
    data: {}
mode: single
You can just use a State condition with a defined duration by using the for variable. If the switch was not turned off at least 10 minutes ago, the actions won’t be executed.
description: ""
condition:
  - condition: state
    state: 'off'
    for:
      minutes: 10
    data: {}
mode: single
The State condition using for handles all that for you.
Thx for the reply, can you give me an example of a for loop, I struggle to do it on the YAML code
Not a for loop… the configuration variable for which adds a duration requirement (see the State Condition my previous post).
