Joe – I did the same thing and ended up doing it a bit differently, and it works very well for the conditional images, but just “ok” for the text resizing. (You can see that “Mode” and "Fans’ run into each other, which they don’t on the iPad on the fridge.) Here’s what I have:
The things I did:
- For conditional images, I created one base image and then a set of identical overlay images with transparency everywhere except where they were different.
- The overlay images then appear when sensors are true. For example, the warning triangle for the filter on the heat exchanger is a transparent png with just that triangle which is visible when the warning is on.
- I have three images for the extract and supply fan (low/med/high) and a sensor that tells the UI which image to overlay.
- I found the graphics were easy to do if I did the following: Create the whole thing in PowerPoint, copy/paste it into Apple’s Preview (as a PDF), save it as a png (each time with the same resolution), then simply use Apple’s Preview to delete all the parts I wanted to be transparent.
Base image:
Heat exchanger warning image:
High extract fan image:
Here is that code:
type: picture-elements
image: /local/heat_graphics2/base3_all_off.png
theme: light
elements:
- entity: binary_sensor.alarm
type: image
image: /local/heat_graphics2/blank.png
state_image:
'on': /local/heat_graphics2/base3_heatpump_warning.png
style:
left: 0%
top: 0%
transform: none
width: 100%
- entity: sensor.ftx_extract_fan_mode
type: image
state_image:
Low: /local/heat_graphics2/base3_ftx_extract_low.png
Normal: /local/heat_graphics2/base3_ftx_extract_normal.png
High: /local/heat_graphics2/base3_ftx_extract_high.png
style:
left: 0%
top: 0%
transform: none
width: 100%
For the text, I had to be a bit careful of two things: size and position.
- For the position it was important to experiment on whether it was best to specify the right/left or top/bottom positions for each item and the offset. Getting the right one really helped with the positioning when it moved.
- For the size, I also had to play with that.
Here are some examples of my positioning:
- entity: sensor.ftx_extract_temperature_filtered
style:
left: 79.5%
top: 30%
transform: translate(0%,-50%)
font-size: 1.5vw
type: state-label
- entity: sensor.ftx_supply_temperature
style:
right: 36%
top: 30%
transform: translate(50%,-50%)
font-size: 1.5vw
type: state-label
Here’s my full configuration for showing our house heat pump, hot water, heat exchanger, and temperatures:
theme: light
elements:
- entity: binary_sensor.pump_cold_circuit
type: image
state_image:
'on': /local/heat_graphics2/base3_brine_on.png
style:
left: 0%
top: 0%
transform: none
width: 100%
- entity: binary_sensor.compressor
type: image
state_image:
'on': /local/heat_graphics2/base3_compressor_on.png
style:
left: 0%
top: 0%
transform: none
width: 100%
- entity: sensor.heatpump_status_direct
type: image
state_image:
Idle: /local/heat_graphics2/blank.png
Water Heat Pumping: /local/heat_graphics2/base3_water_heat_on.png
Floor Heat Pumping: /local/heat_graphics2/base3_floor_heat_on.png
style:
left: 0%
top: 0%
transform: none
width: 100%
- entity: sensor.ftx_supply_fan_mode
type: image
state_image:
Low: /local/heat_graphics2/base3_ftx_supply_low.png
Normal: /local/heat_graphics2/base3_ftx_supply_normal.png
High: /local/heat_graphics2/base3_ftx_supply_high.png
style:
left: 0%
top: 0%
transform: none
width: 100%
type: image
state_image:
style:
left: 0%
top: 0%
transform: none
width: 100%
- entity: binary_sensor.pump_radiator
type: image
state_image:
'on': /local/heat_graphics2/base3_floor_on.png
style:
left: 0%
top: 0%
transform: none
width: 100%
- entity: sensor.ftx_heater_on
type: image
state_image:
'on': /local/heat_graphics2/base3_ftx_electric_on.png
'off': /local/heat_graphics2/blank.png
style:
left: 0%
top: 0%
transform: none
width: 100%
- entity: sensor.heatpump_heater_on
type: image
state_image:
'on': /local/heat_graphics2/base3_heat_pump_electric_on.png
style:
left: 0%
top: 0%
transform: none
width: 100%
type: image
state_image:
style:
left: 0%
top: 0%
transform: none
width: 100%
- entity: binary_sensor.ftx_alarm
type: image
state_image:
'on': /local/heat_graphics2/base3_ftx_warning.png
style:
left: 0%
top: 0%
transform: none
width: 100%
- entity: climate.room_temp_setpoint
attribute: current_temperature
style:
left: 2%
top: 50.5%
transform: translate(0%, -50%)
font-size: 1.5vw
text-decoration: underline
type: state-label
prefix: 'Setpoint: '
suffix: °C
type: state-label
style:
right: 46.5%
top: 81%
font-size: 1vw
- entity: sensor.brine_out_condenser
style:
right: 86%
top: 58.8%
font-size: 1.5vw
type: state-label
- entity: sensor.brine_in_evaporator
style:
right: 86%
top: 70%
font-size: 1.5vw
type: state-label
- entity: sensor.radiator_forward
style:
left: 83.5%
top: 63.5%
font-size: 1.5vw
type: state-label
- entity: sensor.heating_setpoint
style:
left: 83.5%
top: 67.5%
font-size: 1vw
prefix: 'Target: '
type: state-label
- entity: sensor.heat_carrier_forwrd
style:
right: 45.7%
top: 58.8%
font-size: 1.5vw
type: state-label
- entity: sensor.heat_carrier_return
style:
right: 45.7%
top: 70%
font-size: 1.5vw
type: state-label
- entity: sensor.warm_water_1_top
style:
left: 73.8%
top: 81.6%
font-size: 1.5vw
type: state-label
- entity: sensor.hot_gas_compr
style:
right: 68%
top: 58.8%
font-size: 1.5vw
type: state-label
- entity: sensor.heat_pump_outdoor_temperature_without_offset
style:
left: 7%
top: 81%
font-size: 1vw
type: state-label
prefix: 'Outside: '
- entity: sensor.add_heat_status
style:
left: 42%
bottom: 45%
font-size: 1.5vw
transform: translate(-50%,50%)
type: state-label
- entity: sensor.ftx_humidity_filtered
suffix: RH
style:
left: 79.5%
top: 26.5%
font-size: 1.5vw
type: state-label
style:
left: 79.5%
top: 30%
font-size: 1.5vw
type: state-label
style:
right: 36%
top: 30%
font-size: 1.5vw
type: state-label
- entity: sensor.ftx_exhaust_temperature
style:
right: 94%
top: 12.5%
font-size: 1.5vw
type: state-label
- entity: sensor.ftx_outdoor_temperature
style:
right: 94%
top: 22.5%
font-size: 1.5vw
type: state-label
- entity: sensor.ftx_heater_active
type: state-label
style:
left: 44%
top: 30%
font-size: 1.5vw
transform: translate(-50%,-50%)
- entity: sensor.ftx_heat_exchanger_active
type: state-label
style:
left: 22%
top: 18%
font-size: 1.5vw
- entity: sensor.ftx_extract_efficiency
type: state-label
style:
left: 28%
top: 26.5%
font-size: 1vw
suffix: ' eff'
- entity: sensor.ftx_exhaust_efficiency
type: state-label
style:
left: 28%
top: 8.5%
font-size: 1vw
suffix: ' eff'
- entity: sensor.ftx_supply_fan_speed_percent
type: state-label
style:
left: 36.5%
top: 30%
font-size: 1.5vw
- entity: sensor.ftx_extract_fan_speed_percent
type: state-label
style:
left: 36.5%
top: 5.7%
font-size: 1.5vw
- entity: sensor.kitchen_fan_status
type: state-label
style:
left: 92.5%
top: 54%
font-size: 1.5vw
- entity: sensor.bathroom_humidity
type: state-label
suffix: RH
style:
left: 88.5%
top: 40%
font-size: 1.5vw
- entity: sensor.bathroom_temperature
type: state-label
style:
left: 88.5%
top: 43.5%
font-size: 1.5vw
- entity: sensor.upstairs_humidity
type: state-label
suffix: RH
style:
left: 78%
top: 42%
font-size: 1.5vw
- entity: sensor.upstairs_temperature
type: state-label
style:
left: 69.5%
top: 42%
font-size: 1.5vw
- entity: sensor.downstairs_humidity
type: state-label
suffix: RH
style:
left: 78%
top: 54%
font-size: 1.5vw
- entity: sensor.downstairs_temperature
type: state-label
style:
left: 69.5%
top: 54%
font-size: 1.5vw
- entity: sensor.behind_house_temperature
type: state-label
style:
right: 32.0%
top: 54%
font-size: 1.5vw
- entity: sensor.behind_house_luminance
type: state-label
prefix: ☀️
style:
right: 0.5%
top: 2%
font-size: 1.5vw
- entity: input_number.ftx_temperature_setpoint
style:
left: 19%
top: 4%
font-size: 1.5vw
type: state-label
- entity: input_select.ftx_active_user_mode
type: state-label
style:
left: 19%
top: 34.4%
font-size: 1.5vw
prefix: 'Mode: '
- entity: input_select.ftx_manual_fan_speed
type: state-label
style:
left: 36.5%
top: 34.4%
transform: translate(-50%, -50%)
font-size: 1.5vw
prefix: 'Fans: '
- entity: switch.ftx_eco_mode_enabled
type: state-label
style:
left: 44%
top: 34.4%
font-size: 1.5vw
prefix: 'Eco: '
