I have the below automation which is not triggering. I’ve checked the condition template in dev tools and the output is true, but still the automation doesn’t do what it supposed to do. Would anyone be able to provide me a suggestion where I have the problem/mistake.
- alias: 'Motion Sensor Landing after Midnight - Lights Off'
initial_state: 'on'
- platform: state
entity_id: binary_sensor.hue_motion_sensor_1_motion, binary_sensor.0x00158d0001d632fa_occupancy
to: 'off'
condition:
- condition: state
entity_id: light.landing_lights
state: 'on'
- condition: time
after: '00:00:00'
- condition: sun
before: sunrise
- condition: template
value_template: '{{ as_timestamp(now()) - as_timestamp(states.automation.motion_sensor_landing_after_midnight_lights_on.attributes.last_triggered) | int > 300}}'
- service: homeassistant.turn_off
You are calculating whether the lights were turned on at least 300 seconds ago as a condition.
This trigger will only fire, when one of those two sensors goes from to off. If motion is only detected before that 5 minutes, and then not again after it, the trigger will not fire, and your lights will not go off. This means the lights can stay on infinitely, if no motion is detected, to produce you ‘off’ event trigger.
If you intend for the lights to go off after 5 minutes, you should use a timer to count down, and then have the motion sensor to: ‘on’ state reset the timer back to five minutes.
As a side note, you should probably include motion sensor state from:on as without it, this allows the sensor to disconnect and go from unavailable to off, even if its really off->off.
Then, I have 2 automations is place:
1st - at midnight I change the scene on landing if the landing lights are on and I change the state of the motion sensors for landing - on/off. This “activates” my 2nd automation.
1st automation
- alias: 'Midnight scene automation'
initial_state: 'on'
platform: time
at: '00:00:00'
condition:
- condition: state
state: 'on'
- service: script.turn_on
data_template:
entity_id: script.2spots_on
- service: python_script.set_state
data_template:
entity_id: binary_sensor.0x00158d0001d632fa_occupancy
state: 'on'
data_template:
state: 'on'
# No need to set the state of the hue motion sensor back to off as it goes by default
- delay:
seconds: 1
state: 'off'
2nd automation
initial_state: 'on'
- platform: state
to: 'off'
for:
minutes: 5
condition:
- condition: state
state: 'on'
- condition: time
after: '00:00:00'
- condition: sun
before: sunrise
I hope it can help someone in case they have similar issues as I had.
