I have an automation, which is triggered when any of two sensors changes his state.
In the action-part I want to distinguish between the triggering sensor has no value (empty string) or has some value (string).
To avoid some nested and / or conditions I want to use the trigger.entity_id
- if:
- condition: template
value_template: "{{ is_state('trigger.entity_id ', '') }}"
then:
But this doesn’t work! Then automation executes always the else-path
, even when the value of the triggering sensor is empty.
When I use the entity_id of one of the sensors (e.g. sensor.ccu3_sv_gong_eg_kanalaktion
) instead of trigger.entity_id
, then it will work (for this sensor). So the syntax seams to be ok.
But why doesn’t it work with trigger.entity_id
Here is the complete automation:
alias: hm_Gong Kanalaktion v2
description: ""
- platform: state
entity_id:
- sensor.ccu3_sv_gong_eg_kanalaktion
to: null
- platform: state
entity_id:
- sensor.ccu3_sv_gong_og_kanalaktion
to: null
condition: []
- if:
then:
- service: homematicip_local.set_device_value
device_id: "{{ trigger.id }}"
channel: 2
parameter: STATE
value_type: boolean
value: false
channel: 1
parameter: STATE
value: false
value_type: boolean
else:
channel: 2
parameter: SUBMIT
value: "{{ trigger.to_state.state }}"
value_type: string
channel: 1
parameter: STATE
value: true
value_type: boolean
mode: queued
