I have separate light switches for the hallway on each level of my house (basement, ground floor and second floor), Separate to this I have light switches at the staircases to control the light on the upstairs and downstairs. All light switches are planned to be extended with a shelly device to be able to control them also via home assistant.
Now it sometimes happens that the hallway light on the second floor has been turned on. You have enough light to walk downstairs and arriving at ground level you recognize you cannot turn off the light. So I would like to add this opportunity. The idea is to long-click the stairways light switch to toggle the hallway light on the second floor.
## Toggle Upwards Stairs Light
## Shelly is in detached mode to not switch power,
## but control via staircase lighting via Zigbee protocol instead
- alias: Light - Toggle Upwards Stairs Light
platform: event
event_type: shelly.click
event_data:
device: shellyswitch25-84CCA89F70DD #Shelly 2.5 Flur OG
channel: 2 #Channel 2=Staircase
click_type: single
service: light.toggle
entity_id: light.staircase_up
## Toggle Upstairs Corridor Lights from Staircase Switch
- alias: Light - Toggle Upstairs Corridor Lights
platform: event
event_data:
click_type: long
entity_id: light.corridor_upstairs
Towards the basement I would like to allways turn on the basement corridor light light.corridor_basement
, when the light switch for the downstairs lighting is pressed. But the basement corridor light should remain to be controlled separatley from the downstairs lighting.
## Toggle Downwards Stairs Light
- alias: Light - Toggle Downwards Stairs Light
platform: event
event_data:
device: shellyswitch25-84CCA89FCDC7 #Shelly 2.5 Flur UG
click_type: single
entity_id:
- light.staircase_down
# - light.corridor_basement #TBD Ensure that it toggles to the same state!
i.e. the light.corridor_basement
only needs to be toggled, if it is in the same state than the light.staircase_down
. Is there anyway to add this condition priort to calling the toggle of light.corridor_basement
