- id: '1597055016189'
alias: Bike Mode Door Garage Open when arriving home
description: Open Garage Door when entering Bike Zone if Bike Mode On and Alarm
Not Set
- entity_id: device_tracker.gt_i9505
event: enter
platform: zone
zone: zone.bike_home
condition:
- condition: state
entity_id: binary_sensor.bike_mode
state: 'on'
- condition: state
entity_id: binary_sensor.garage_alarm_set
state: 'off'
- condition: state
entity_id: timer.garage_door_inhibit
state: '?'
- data: {}
entity_id: switch.garage_door_open_2
service: switch.turn_on
mode: single
So its the timer.garage_door_inhibit that would be started with 00:10:00 when I leave the zone
If I come back after 10 Mins I want the door to open.
condition: state
state: “What do I put Here for when the times has finished”
Sorry I had not changed my requirements but just flipped the logic.
I was thinking that if the timer was still running i.e. “NOT Idle” then don’t allow the door to open, but of course thinking about it and seeing that reply I can allow the door to open when the timer is finished.
You do realize that those will both result in the exact same outcome, don’t you?
Unless you are in the habit of pausing your timer then “NOT idle == active”. And “NOT active == idle”.
and if you do pause the timer then all bets are off on when the automation will actually trigger and it would probably defeat the whole purpose of using a timer in this case.
