I’ve searched the community for similar questions, I found, but with no real solutions to my problem… So here it goes:
I’ve set up the ifttt integration as described here https://www.home-assistant.io/integrations/ifttt/
The automation works perfectly on the .turn_on service.
However for the .set_value service, that requires a ‘value’ attribute, I need to add
data_template:
entity_id: '{{ trigger.event.data.entity_id }}'
value: '{{ trigger.event.data.value }}'
service_template: '{{ trigger.event.data.service }}'
By adding the ‘value’ attribute the .turn_on service will not work as it does not expect a value attribute.
I’ve tried:
data_template:
{% if trigger.event.data.value %}
{% else %}
But it gives an error (Message malformed: required key not provided @ data[‘action’][0][‘delay’]
Any idea on how can I make the ‘value’ attribute conditional?
