This is driving me batty, and I feel like I’m probably missing some silly little nuance. Maybe y’all can help.
Here’s the scenario: switch.space_heater is a template switch that is connected to an IR Blaster. The switch can get out of sync with what’s happening since it’s simply a “toggle power”-type command. I have the device plugged into a switched outlet, switch.office_heater_mss110_main_channel. If the switch.space_heater is turned on while the switched outlet is off, I want it to turn the switch.space_heater back off.
What am I doing wrong???
- id: '1616495711825'
alias: IR Heater not turning on if Heater Control is off
description: ''
- platform: state
entity_id: switch.space_heater
attribute: mode
to: 'on'
condition:
- condition: state
entity_id: switch.office_heater_mss110_main_channel
state: 'off'
- service: switch.turn_off
data: {}
mode: single
I assume your problem is simply that this automation is not working as expected?
Does it work if you manually execute it from the Automations page? If it does, the action is correct.
Does it work if you remove the condition (i.e. immediately turn the heater back off when it is turned on)?
Could you paste a screenshot from Developer Tools / States showing what switch.space_heater looks like? Curious about the attribute: mode which I suspect may be the issue.
You’re absolutely correct: not working as expected. When I execute from Automations, it does as expected–however, independent of the condition. Regardless of the condition of the respective switch, it will still execute.
Is this what you’re looking for?? My gut says no…
Here’s how I have it defined in configuration.yaml:
Manual execution bypasses the trigger and condition, and executes the action.
That screenshot is exactly what I needed to see.
There is no mode attribute set up, so remove the attribute: mode line from the trigger to get it to work on the switch state rather than a non-existent attribute [docs]. If there had been such an attribute, it would have been shown in the right-hand column, and would be an odd (but not impossible) way to configure a switch.
The id line suggests it was created by the GUI, so curious to know how that attribute line got there…
I believe the UI editor has a default “attribute” selection box that for some reason people think they need to always fill in with something (even if it doesn’t seem to make sense).
I’m seeing this all the time in “why won’t my automation work?” threads.
It’s definitely a flaw in the docs or the non-intuitive design of the editor tht saeems to be the issue since so many people are doing it.
I have also noticed a recent uptick in support requests featuring State Triggers with unnecessary references to an attribute (and quite often the attribute doesn’t even exist for the specified entity).
It’s unclear to me why people are including an attribute (especially when it doesn’t even exist) given that the field clearly indicates that it is optional.
Perhaps smibrandon can shed some light on this matter. Why include the mode attribute?
I wonder if there’s some way the GUI auto-populates it, either visibly or behind the scenes. I can’t find any example document or tutorial that could have caused it.
yeah, that example really isn’t a good comparison since that is the expected/desired behavior for the UI editors to automatically add an ‘id’ to the automations and scripts. those are required to make them editable via the UI so they get added automatically.
Yeah, I also tried it and it certainly doesn’t do it every time. I was suggesting there may be some sort of edge case where the information gets populated, perhaps invisibly and perhaps with a different type of automation (device, event etc) then not erased when the desired selections are made.
It wasn’t the id I was pointing out, but the superfluous and seemingly wrong attribute: mode line in that code. Seems a bit coincidental that two people would use the same additional automation-breaking line: I suspect either there’s some document somewhere that people are following, or it’s a side-effect of an edge case in the UI.
I created a dummy automation in the Automation Editor, and checked the YAML, and no attribute. I went back into my automation (GUI), selected an attribute, then tried to remove it by highlighting the text and deleting it. The attribute field appeared empty, however when clicking the dropdown, it still had an item checked…which also appeared in my YAML.
Takeaway: Need to use the X on the right side of the field to actually remove any attribute
Here’s the dropdown after my attempt at removing the Attribute.
Thanks for confirming that it’s difficult to do this “accidentally”. You have to deliberately select an item from the list.
What is misleading is that the editor allows one to backspace/delete the text. It gives the impression that the attribute value has been removed but, in fact, it still remains. That seems to be a bug.
BTW, what kind of entity did you select for the State Trigger that offers all of those attributes? I’ve tried several switches (based on different platforms) and the only attribute offered is FriendlyName.
Like I said, I only see FriendlyName in the attribute list (using version 2021.3.4).
Curious to learn why the OP sees more items in the list.
EDIT
I discovered that if you backspace/delete the attribute, the editor temporarily hides the Save button. The moment you move the focus away from the Attribute field, the Save button re-appears. Switching to YAML mode shows the attribute has indeed been removed.
The OP’s automation, the one in the first post, contains a State Trigger for a switch along with a mode attribute.
- platform: state
entity_id: switch.space_heater #<---- switch, not automation
attribute: mode #<---- this attribute doesn't exist for switch entities
to: 'on'
How did the OP manage to achieve that combination?
BTW, this investigation is moot if the OP isn’t using the latest version.
Yeah I know. I wonder if @smibrandon started by creating a “skeleton” using the UI and an automation entity (as it’s the first thing on the list), with the attribute: mode inadvertently set, then proceeded to update the entity to a switch in YAML mode without removing the attribute line…
I confirmed that the sequence of events you described will result in the automation entity’s mode attribute mistakenly assigned to a switch entity. I’d call that a bug; changing the entity’s domain (i.e. from automation to switch) should purge the attribute field.
I’m not in agreement with the OP’s characterization of this as being done “accidentally”. One must deliberately perform a very particular sequence of steps to force this bug to appear. Although automations may be the first to appear in the entity list (assuming one doesn’t have an alarm_control_panel), you still have to select one and then select the second (or third) item in the list to get mode.
If anyone wants to write this up as an Issue in the Frontend repo, have at it.
