Is it possible to only display a badge only when something is on, for example, a light? The documentation is very vague in explaining. I also tried the suggestions in this thread but it also doesn’t work.
Thank you.
Thank you.
Copy this into your raw config below badges: (remove the [] )
- type: entity-filter
entities:
- entity: light.kugellampe_lang
state_filter:
- 'on'
The documentation examples work, but yes, it’s not good enough explained, they should look like this:
# raw config
- title: Home
badges:
entities:
- entity: light.bed_light
- light.kitchen_lights
- light.ceiling_lights
state_filter:
- "on"
# raw config
- title: Home
badges:
state_filter:
- "on"
- operator: ">"
value: 90
entities:
- sensor.water_leak
- sensor.outside_temp
- entity: sensor.humidity_and_temp
state_filter:
- operator: ">"
value: 50
attribute: humidity
