Hello folks,
I am working on a blueprint to automate presense detection. It is based on PIR (binary sensors) and ESPresense room occupancy via mqtt_room.
The mqtt_room entities are sensors that output a string corresponding to the room that the tracked device is currently detected to be at.
The particular snippet I am interested in is this:
- condition: state
entity_id: !input espresense_devices
match: any
state: "{{ state_attr(occupancy_room, 'friendly_name') }}"
In this example, the “entity_id” (!input espresense_devices
) is an array of mqtt_room sensors, which all have a string value of the room they are detected at, i.e. “living_room”.
The “state” rule to match, is the “friendly_name” attribute of the custom binary_input entity “occupancy_room”. The value of the “friendly_name” is the exact same string as the one outputted by the mqtt_room, for our example say the value is “living_room”.
I cannot manage to get a match between the multiple presense entities and an attribute of an entity… I’ve tried all sorts of ways and combinations to now avail…
I am pasting the entire blueprint where I am using a variable to use in the “state” property of the condition.
blueprint:
description: Setups presense automation for a room. This Blueprint will
Trigger when any of the following happen
* Any of the binary motion sensors detect motion
* A tracked device changes room
Will then turn on presense for the configured room or turn it off
when there is no person or motion detected.
Inspired by this post https://community.home-assistant.io/t/my-espresense-setup-and-lovelace-dashboard/472705
Blueprint version 1
domain: automation
source_url: https://gist.github.com/thanpolas/TBD
input:
motion_entities:
selector:
entity:
domain: binary_sensor
device_class: motion
multiple: true
espresense_devices:
selector:
entity:
domain: sensor
multiple: true
occupancy_room:
selector:
entity:
domain: input_boolean
multiple: false
# Automation Configuration start
mode: single
max_exceeded: silent
platform: state
entity_id: !input motion_entities
condition: []
variables:
occupancy_room: !input occupancy_room
occupancy_room_id: "{{ state_attr(occupancy_room, 'friendly_name') }}"
is_espresense_devices_in_room: is_state(!input espresense_devices, occupancy_room_id)
- choose:
- conditions:
- condition: or
conditions:
- condition: state
state: "on"
match: any
- condition: state
match: any
state: >
{{ occupancy_room_id }}
sequence:
entity_id: !input occupancy_room
- conditions:
- condition: state
state: "off"
- condition: not
conditions:
- condition: state
state: "{% state_attr(!input occupancy_room, 'friendly_name') %}"
match: any
sequence:
- service: input_boolean.turn_off
