Hi all,
Is it possible to have a conditional card inside a vertical stack card ?
My attempts do not seem to display any of the cards inside the vertical stack (although the condition is met perfectly)…
Thx
Koen
Hi all,
Thx
Koen
Yes, it works for me. I actually have three conditional cards at the top of a vertical stack. Here’s the first one:
- type: vertical-stack
cards:
- type: conditional
card:
type: entity-filter
title: Doors Unlocked
show_header_toggle: false
entities:
- lock.dr_door_lock
- lock.front_door_lock
- lock.garage_side_door_lock
state_filter:
- 'unlocked'
show_empty: false
card:
type: glance
show_state: false
conditions:
- entity: sensor.doors_unlocked
state: 'True'
Maybe you need quotes around the condition? Maybe I can spot the difference if you post the code.
Thx, Rob. I’ll investigate a bit further !
Still puzzled…
Can’t get it working still.
# "Test" View
- title: Test
path: Test
background: var(--background-image)
badges: []
cards:
cards:
- type: conditional
conditions:
- entity: input_select.algemeen
state: 'Home'
card:
- type: markdown
content: Test 1
Try with two fewer spaces before - type: conditional
. I haven’t seen this documented anywhere, but mine as well as rccoleman’s seem to be working this way…
# "Test" View
- title: Test
path: Test
badges: []
cards:
cards:
- type: conditional
conditions:
state: 'Home'
card:
- type: markdown
content: Test 1
Finally ! Got it working.
The solution is not to use “- type: …” in the “card:” section of the conditional card, but rather use “type: …” without the dash…
Many thanks for your kind support !!!
# "Try" View
- title: Try
path: Try
badges: []
cards:
cards:
- type: conditional
conditions:
state: Home
card:
type: markdown
content: test 1
Ah, good eye!
I overlooked that, but it makes sense in retrospect since each condition only applies to a single card (and dashes are for multiple cards).
Hi Jason
I have the opposite problem.
The card i displayed even if the condition “state_not” is meet?
The card was setup using the UI.
type: horizontal-stack
cards:
- type: conditional
conditions:
- entity: sensor.pollen_viborg_graes
state_not: '''-'''
card:
type: gauge
min: 0
max: 100
severity:
green: 0
yellow: 10
red: 50
- type: conditional
conditions:
- entity: sensor.pollen_viborg_bynke
state_not: '''-'''
card:
type: gauge
min: 0
max: 100
severity:
green: 0
yellow: 10
red: 50
- type: conditional
conditions:
- entity: sensor.pollen_viborg_elm
state_not: '''-'''
card:
type: gauge
min: 0
max: 100
severity:
green: 0
yellow: 10
red: 50
- type: conditional
conditions:
- entity: sensor.pollen_viborg_birk
state_not: '''-'''
card:
type: gauge
min: 0
max: 100
severity:
green: 0
yellow: 10
red: 50
- type: conditional
conditions:
- entity: sensor.pollen_viborg_hassel
state_not: '''-'''
card:
type: gauge
min: 0
max: 100
severity:
green: 0
yellow: 10
red: 50
- type: conditional
conditions:
state_not: '''-'''
card:
type: gauge
min: 0
max: 100
severity:
green: 0
yellow: 10
Any Idea what is going wrong?
I thank you in advance
Found the solution.
it was a typeO
state_not: '-'
#instead of
state_not: '''-'''
