I’ve searched for the answer to this, but not found anything to help.
I have two conditional cards in a vertical stack to show at the top of the frontend, but only during an automation.
The automations switch a hot water socket on, delay for either 1 or 2 hours and then switch it off. I only want to see the two conditional cards if one of these two automations is somewhere in the delay phase on the frontend.
I thought I could use the automation entity as a condition if the state was = ‘on’ but it doesn’t work. I’ve tried true too with the same result.
Is there a state I’m missing for automations, or is there a better way to achieve the same thing. I could just show the card based on the switch state, but I’d prefer to see it only when the automations are running.
type: vertical-stack
cards:
- type: conditional
conditions:
- entity: >-
automation.switch_the_hot_water_on_for_1_hour_in_response_to_telegram_check
state: 'true'
card:
type: markdown
content: _The Hot Water has been activated for 1 hour_
title: Hot Water heating
theme: slate
- type: conditional
conditions:
- entity: >-
automation.switch_the_hot_water_on_for_2_hours_in_response_to_telegram_check
state: 'true'
card:
type: markdown
content: _The Hot Water has been activated for 2 hours_
