I’ve never used the conditional so much appreciative if someone could lend a hand.
I have the below. What I’m trying to do is only show entity: input_text.lockcode_status if it’s value is not blank. I’m not sure if what I have for row is correct. Error I receive is Conditions should be in an array.
- type: entities
entities:
- entity: input_text.lockcode_code
- entity: input_select.lockcode_selectuser
- entity: input_select.lockcode_slot
- type: conditional
conditions:
state_not: ""
row: input_text.lockcode_status
- type: "custom:button-card"
entity: input_boolean.lockcode_submitcode
show_state: false
show_icon: false
show_label: true
label: >
if (states['input_text.lockcode_status'].state != "")
return "Reset";
else
return "Submit";
show_name: false
I just had a quick look at one of my conditional cards and the difference I see is that mine is more like this:
- type: entities
entities:
- type: conditional
conditions:
- entity: input_text.lockcode_status
state_not: ""
show_state: false
show_icon: false
show_label: true
label: >
return "Reset";
else
return "Submit";
show_name: false
which should fix the ‘array’ issue I think
Now I get the below. Must be a way to check for nulls.
Conditions are invalid.
type: conditional
conditions:
state_not: ''
Ok, found a thread where someone mentioned using none which seems to get pass that error but now it’s saying. Wondering if this is because of what I pass in for row?
Config is not an object
I haven’t used the ‘row’ parameter before. Where are you getting that from? It’s not a valid entry for a conditional card
Look at the entities card and scroll down to the conditional section. @sparkydave This is not the same as the conditional card. This is the conditional row that you can do inside the entities card.
Ah, my bad. I’ll have a play with it and see what I can come up with. Have you tried using a different entity for the ‘row’ element?
EDIT: it really sucks that there aren’t any examples in the docs for this as I can’t get it to work either. I get the some error ‘Config is not an object’…so what can we use as the ‘row’?
EDIT 2: figured it out with some searching on this forum, this this:
type: conditional
conditions:
state_not: ''
row:
@sparkydave Thanks for the assist brother. I was actually trying different configs since it states row accepts map and not list but I was adding map entity without the word entity.
I will look into updating the doc with an example for others so we can at least give back from what we learn.
Yeah, the docs certainly aren’t intuitive in many places. Unfortunately unless you know the answer you can’t send in a PR for the doc change. Catch 22. That will be good if you put one in for this, otherwise I can. Either way, cheers.
I’m still going to have to work on the null value as it looks like others have ran into issues getting conditional to check for nulls.
brunogp32
(brunogp32)
May 25, 2021, 11:47am
12
My example with command remote broadlink if TV is on:
type: entities
entities:
- type: button
icon: 'mdi:power'
action_name: Ligar/Desligar
tap_action:
action: call-service
service: remote.send_command
service_data:
entity_id: remote.broadlink_sala_remote
command: >-
b64:JgBGAJKVDzsQOhA6EBUQFRAVERQRFBE5EDoSOBEUERQRFBAVEBURFBE5ERQRFBAVERQRFBEUETkRFBE5ETkRORE5EToQOg8ADQUAAA==
- type: button
icon: 'mdi:video-input-hdmi'
action_name: Ligar BOX
tap_action:
service_data:
command: >-
b64:JgBIAAABK5IUERM3EjcSNxITEjcTNhM2EzYTNhQ2EhMWDxITEhIUNRM3EjcSFBISEhMSExISExIUNRM3ETgSNxM2EzYTEhM3EgANBQ==
- type: conditional
conditions:
- entity: media_player.samsung_ue55mu6205
state: 'on'
row:
type: button
icon: 'mdi:menu'
action_name: Menu BOX
tap_action:
service_data:
command: >-
b64:JgBQAAABK5IUERI3FDUTNhMSEzYTNhM3FDUSNxU0ExITExETEhMSNxM2EzYTEhMTERMUERYPEhMSNxM2FDUTNhM2EzYSFBI3FAAEngABKUoVAA0F
- type: conditional
conditions:
state: 'on'
row:
type: button
icon: 'mdi:bullseye'
action_name: OK
tap_action:
service_data:
command: >-
b64:JgCQAAABK5EUEhM4ETcSNxITEjcTNhM2FDUUNRM4ERMSFBETEhIUNhITEhITNRQ3FDUSExI3EhQSNhQ1EzYTNhQ2EjcSExI3EwAEWwABKpISFBE3FDUTNxISEzcTNRQ2EjcSOBE3FBIRExIUERMSOBE3ExISNxQREhUQExITEhQRNxI3EjgUNBQ1EzYTEhQ2EwANBQ==
- type: conditional
conditions:
state: 'on'
row:
type: button
icon: 'mdi:arrow-up-bold-box'
action_name: Para cima
tap_action:
service_data:
command: >-
b64:JgBQAAABKpISFBE3EzYUNhISFDYSNxI3EzYSOBE3ExMSEhQSERMSOBITEzUTEhQ1FBISExISFBIRNxM2EjgSNhM3EzYSExM2FAAEngABKkgUAA0F
- type: conditional
conditions:
state: 'on'
row:
type: button
icon: 'mdi:arrow-down-bold-box'
action_name: Para baixo
tap_action:
service_data:
command: >-
b64:JgBQAAABKpMTExI2FDYSNxITEjcSNxM2EzYTNhM3EhMSExITEhITNhMSExMRNxQ2EhQREhMSExITNhQ2EjcSNxI3FDUTEhQ2EgAEnwABKUoSAA0F
- type: conditional
conditions:
state: 'on'
row:
type: button
icon: 'mdi:arrow-right-bold-box'
action_name: Direita
tap_action:
service_data:
command: >-
b64:JgBQAAABK5ISExM2EjgTNhITEjcTNhQ1EjcTNhQ2ERQSEhMSExITNhQREzYTNxITEhMRFBISEhMUNRI3EzcSNxE4FDUTExE4EgAEnwABKUoSAA0F
- type: conditional
conditions:
state: 'on'
row:
type: button
icon: 'mdi:arrow-left-bold-box'
action_name: Esquerda
tap_action:
service_data:
command: >-
b64:JgBQAAABKpMUEBI4EjgSNhMTETgSNhQ2EjcSNhQ2EhMTEhITExISNhU1EhQSEhI3FBEUEhISEhISOBI3EjcTNhI4ETgSExI4EQAEngABLUkTAA0F
- type: conditional
conditions:
state: 'on'
row:
type: button
icon: 'mdi:television-ambient-light'
action_name: Assistir TV
tap_action:
service_data:
command: >-
b64:JgBGAJKVETkRORE5ERQQFRAVERQQFRE5ETkROREUERQRFBEUERQRORAVERUPOxAVDzsQOhA6EBUQOhA6EBUQOhAVEBUPFhAADQUAAA==
- type: conditional
conditions:
state: 'on'
row:
type: button
icon: 'mdi:volume-plus'
action_name: Aumentar volume
tap_action:
service_data:
command: >-
b64:JgBGAJKVETkRORA6ERQRFBAVEBUQFRA7EDkROhAUERUQFRAUEBYQOhA6EDoPFhAVEBUQFQ8WEBUPFhAVEDoQOhA6EDoQOg8ADQUAAA
- type: conditional
conditions:
state: 'on'
row:
type: button
icon: 'mdi:volume-minus'
action_name: Diminuir volume
tap_action:
service_data:
command: >-
b64:JgBGAJKVEDoSOBE5EBUQFREUERQRFBA6EDoROREUEBURFBEUEBUQOhE5ERQROREUEBURFBAVEBUQFRE5ERQQOhE5EDoQOhAADQUAAA==
- entity: switch.sonoff_10009e5a98_1
- entity: switch.sonoff_10009e5a98_2
- entity: cover.bfcc297f9be785443ex3to
- entity: scene.q8xowymf6rcxmusn
- entity: scene.bpkwqokv9rp5liad
title: Sala
state_color: true
TV is ON:
mat44150
(mat)
August 25, 2021, 9:20pm
13
Isn’t it possible to list several entities under the row
parameter ? Is it necessary to add the conditional line for each entity ?
dbrunt
(Daniel)
September 1, 2021, 11:01am
14
If the condition is the same and you want that conditional row to be button entities then no, you can list multiple buttons on that single conditional row:
type: entities
entities:
- sensor.garage_door_lock_log
- sensor.life360_may_battery
- sensor.time
- type: conditional
conditions:
- entity: binary_sensor.ha_uptodate
state: on
row:
type: buttons
entities:
- lock.garage_door_lock
- lock.front_door_lock
You can only list multiple buttons per row since a single button, attribute, web link, divider and section each occupy an entire row. If you want those types to be conditional, then the condition has to be listed for each of them.
mat44150
(mat)
September 2, 2021, 1:47pm
16
Thanks for your reply. But in my case, I’d like to have several rows (similar to an entity card). I understand it accepts only a single row.
dbrunt
(Daniel)
September 2, 2021, 4:48pm
17
Yes, for each conditional row you’d have to replicate the condition for that entity. If the conditions are the same it’s not a horrendous job with copy/paste in yaml. The card would need to either accept a new element like rows:
which accepted an array of entities or modify row:
to accept either a map or an array of entities for what you’re asking.
type: entities
entities:
- sensor.time
- type: conditional
conditions:
- entity: lock.fron_door_lock
state: unlocked
row:
entity: lock.front_door_lock
- type: conditional
conditions:
- entity: lock.garage_door_lock
state: unlocked
row:
You could use state switch which has more options.
