Hello!
Is it possible to use conditional offset in triggers? If so, what is the syntax? My use case: I turn the heating on 8 hours before I arrive to my country house, and I use a calendar event to set the arrival date/time. But if it’s too cold outside it takes more time to get the comfortable temperature in th house.
So I need smth like: if outside temperature is < -10C use offset of 16 hours, else 8 hours.
My current calendar trigger snippet:
platform: calendar
event: start
offset: "-8:0:0"
entity_id: xxxx.xx.com
