I’m building a script which can send notifications through multiple notification services.
I’m havin trouble using templates for the Companion app notification.
In my script, I have optional parameters (fields), like channel, state, tag, etc.
- service: notify.mobile_app_phone
message: "{{ message }}"
title: "{{ title }}"
channel: "{{ channel | default('') }}"
tag: "{{ tag }}"
persistent: "{{ persistent }}"
color: "{{ '#%02x%02x%02x' | format(color[0], color[1], color[2]) }}"
If I just use them in my script and they are not defined I get the following warning:
Template variable warning: ‘tag’ is undefined when rendering ‘{{ tag }}’
Which is fair enough, if I specify an empty string as a default value, I can get rid of this warning, however what I really want to achive, is I that I don’t even send out the channel parameter for the service call, if the channel field is not defined for the script.
I tried it a couple ways, but I cannot make it work.
Is it creating issues it just a matter of semantics for you?
You cannot template the fields; only values when indicated as such. You’ll need to make multiple scripts and call the one with the number of parameters you have.
IIRC, a value of ‘General’ is sent anyway even when channel
is left blank or not included in the service call configuration.
You may also want to set a default for tag
when persistent
is true, since a tag is required for persistent notifications.
Something like:
channel: "{{ channel | default('General') }}"
tag: "{{ tag or ('Persistent' if persistent else '') }}"
Well yes, I suppose I can set the default values in the template to the default values (false for persistent for example) and empty string to string. I just wanted to avoid sending out empty values. It looks like it’s not a problem for my phone, but I can’t be sure it won’t cause any problem.
And is there a way to add more field-value pairs to the data field?
So I would have an advanced field where I can define more options, because obviously I can’t prepare my script for all the available options.
Well, you can always pass a text blob if you’re willing and able to parse it (e.g. CSV or JSON).
