Hi all,
I’m having an issue with a particular blueprint I’m developing. All of the below code works as expected in the Template tab of Developer Tools, but produces an error when read in as an automation. Does anyone see any obvious issues?
is_zha_group is a custom variable set in my blueprint. The object of the code is to send a zigbee group command if the entity is a zigbee group, and send a zigbee cluster command if the entity is a single device.
sequence: >
{% if is_zha_group == true %}
- service: zha.issue_zigbee_group_command
group: "{{ zha_group }}"
{% else %}
- service: zha.issue_zigbee_cluster_command
ieee: "00:0d:6f:00:16:43:6f:c2"
endpoint_id: 1
command_type: server
{% endif %}
cluster_id: 0x0008
command: 0x0000
args:
- 254
- 150
