Hi, I’m trying to replace my old thermostat and switch to zone control using HA. I’ve come a long way already but fail to get the last part.
What I have are 2 zones with floor heating (kitchen and living room) and both have their respective valves to close / open the zone. I’m able already to close both based on temperature readings, but the final step would be to control my relay for my boiler, so it gets a rest signal once the temperature is in range in both zones.
So what I’d like to achieve are 2 states :
Boiler in production (relay On) :
Trigger at 6AM, and keep in production between 6AM and 23PM while the temperature in one of the zones is below the target temperature (20 degrees).
Boiler in rest (relay off) :
Trigger at 23:00, or if both zones are above the target temperature (20 degrees) between 6AM and 23PM.
Or in other words, turn on at 06:00 and turn off at 23:00, but alternate during this timeframe depending on the temperature (off if both above 20, on if one below 20)
What I have is this :
#### BOILER ON ##########
- id: cv_boiler_on
alias: Boiler CV Aan
description: ''
- platform: time
at: 06:00
condition:
- condition: time
after: 05:59
before: '23:00'
- condition: or
conditions:
- condition: numeric_state
entity_id: sensor.temperatuur_keuken
below: '20'
entity_id: sensor.temperatuur_living
below: '20'
- service: switch.turn_on
entity_id: switch.relay_boiler
mode: single
#### BOILER OFF ##########
- id: cv_boiler_off
alias: Boiler CV Uit
description: relais uit, boiler af
- platform: time
at: '23:00'
condition:
- condition: and
conditions:
- condition: time
after: 05:59
before: '23:00'
above: '20'
above: '20'
- service: switch.turn_off
mode: single
But while testing it doesn’t seem to bother about any of the conditions. The relay goes on and off, but it always does this, while I would expect to ‘fail’ to close the relay if both zones are over 20.
