Conditional test error in template
Hi there,
I want to test in a script if all elements in a group of windows are at a given position.
I tried in template developer tools:
{% set positions = expand('cover.toutes_les_fenetres_velux') | map(attribute='attributes.current_position') %}
{% set p=1 %}
{{ max(positions)>p or min(positions)<p }}
But get the error: UndefinedError: No aggregated item, sequence was empty.
Then I made different tries and was very surprised that the folowing test fails:
{% set p=1 %}
{{ max(positions)>p }}
{{ min(positions)<p }}
But this works:
{% set p=1 %}
And the same for the other test. But the fact that I call two times the variable positions fails. Can anyone explain why?
Post the value of the positions variable.
