Hi - i have been scanning around for some hints on extracting a dict item from a json payload for a trigger.
Use case is to switch on a light for 5mins if motion is detected from a camera
The motion data source is MQTT from KIOS the payload is
{"regionCoordinates":[960,90,1073,413],"numberOfChanges":58,"pathToVideo":"1635183826_5-74409_Backdoor_926-297-1006-468_299_968.mp4","name":"Backdoor","timestamp":"1635183828","microseconds":"6-788969","token":952}
the item i’m looking for is ‘numberOfChanges’ and the trigger should happen if ‘numberOfChanges’ > 1000
the yaml i have in HA is
alias: Turn on front arch light if camera motion detected
description: ''
- platform: mqtt
topic: kios/drive
payload: '{{ trigger.payload_json.numberOfChanges > 1000}}'
condition:
- condition: sun
before: sunrise
after: sunset
- service: switch.turn_on
entity_id: switch.esp_d04edd_2
- delay:
hours: 0
minutes: 5
seconds: 0
milliseconds: 0
- service: switch.turn_off
mode: single
I’m getting the error in HA
ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'trigger' is undefined when rendering '{{ trigger.payload_json.numberOfChanges > 1000}}'
having looked a a few other examples,i have also tried
'{{ trigger.payload_json['numberOfChanges'] > 1000}}'
i also tried changing the operator to == null , but the same error persists.
I have recently switched from OH to HA. So this is bound to be a noobie question… any help would be much appreciated. Thx.
