Is it possible to use a conditional card within a grid so that a certain card slot shows 1 of 2 cards?
i.e. in a 2x2 grid could i have the bottom right show card A if a condition is true or card B if it is false?
Normally you can achieve such things if you know the layout won’t be affected but this involves adding more cards to your 2x2 grid than the required 4
Not 100% sure if this is what you’re looking for, but I’m using this 2x2 grid and when any of the sensors is not available I just see the gauges for the ones that are:
cards:
- cards:
- card:
entity: sensor.igrill2_probe_1
max: 200
min: 0
severity:
green: 130
red: 165
yellow: 145
theme: default
type: gauge
conditions:
- entity: sensor.igrill2_probe_1
state_not: unavailable
type: conditional
- card:
entity: sensor.igrill2_battery
max: 100
min: 0
theme: default
type: gauge
conditions:
- entity: sensor.igrill2_battery
state_not: unknown
type: conditional
type: horizontal-stack
- cards:
- card:
entity: sensor.igrill2_probe_2
max: 200
min: 0
severity:
green: 130
red: 165
yellow: 145
theme: default
type: gauge
conditions:
- entity: sensor.igrill2_probe_2
type: conditional
- card:
entity: sensor.igrill2_ambient_temp
max: 550
min: 0
theme: default
type: gauge
conditions:
- entity: sensor.igrill2_ambient_temp
type: conditional
type: vertical-stack
In my case, I almost always see sensor.igrill2_battery
because MQTT maintains the value unless I do a restart.
The ‘probe’ and ‘ambient_temp’ gauges are only visible when they are actually available in the system; for my iGrill2 thermometer that means: when the thermometer base unit is connected and the probes are plugged into the base unit.
This is what the UI shows in edit mode:
And this is what the UI shows right now because the iGrill2 is currently not connected.
Here are some more screenshots:
not quite my aim but i do like what you’ve achieved there. Imagine if one of those 4 was showing either (and this is making something up) if it was night or day. Card A for night, card B for day
I think you should be able to achieve that by using two conditional cards, one with above_horizon and the other with below_horizon.
that was more of an example :). In that scenario though id specify a 2 column grid, each with a vertical stack card. then in column 2 id need 3 rows right? maybe im over complicating things
