Ok - bear in mind I have a extensive background in I.T. scripting and automation - wrapping my head around this product (and really enjoying the challenge I might add…). But I have a question…
So in normal IT scripting languages, you can do if/then/else statements…but I’m wondering if the automation in HA supports this logic.
The reason I ask is the following…
I got a minimote working and pressing 1 turns the light on and pressing 2 on the remote turns it off. But is there an option turn script in button 1 to say “button 1 pressed - if light off, turn on else if light on, turn light off” - so I could use 1 button for 1 light?
I’m assuming conditions are somewhat of the answer, but I wasn’t sure how to get 2 actions to tie to automation. I get the impression this is probably not an option, at least in the automation, based on how the conditions page says this “Conditions are an optional part of an automation rule and be used to prevent an action from happening when triggered.”
So it sounds like conditions are meant to stop actions - but can you have mutliple conditions/actions in one automation rule?
If scripts are the answer, that’s fine - I could have the remote button 1 fire off a script, but I didn’t see if/then/else in the scripting language.
Thoughts and ideas would be much appreciated. If I’ve missed something core to the product, happy to re-read and learn, just couldn’t find it on my own.
Thanks for all the help!
