Conditions of sensor failed
Hello Team
i have created two sensors, and i want to be notified if the value is not reached
the HA dev_template return me correctly the values.
{{ (state_attr(‘frigo_consomation’, ‘today_energy_kwh’)|float) > float(0.1) }}
=> send False
and it’s ok,
but when i put in automation.yaml this code,
      condition:
      conditions: or
       - condition: template
          value_template: "{{ (state_attr('frigo_consomation', 'today_energy_kwh')|float) > float(0.1) }}"
          value_template: "{{ (state_attr('congelateur_consomation', 'today_energy_kwh')|float) > float(0.1) }}"
at verfication time i have the message:
Error loading /config/configuration.yaml: mapping values are not allowed here
Thanks for yours help.
Bruno
Can you format your code using the blue bar on top? Sounds like an indentation issue but without formatting your code correctly I can’t verify this
i have simplified the code
this one is ko:
  condition:
        condition: template
        value_template: '{% if (value.congelateur_consomation |float) < float(0.3)%}true{%else%}false{%endif%}'
and this one too; ko
  condition:
    condition: template
on your first code example, there are missing indentations
Try this and see if it passes the code check:
      condition:
        conditions: or
this one is ok, run nice :
  alias: verif frigo
  - at: '18:30:00'
    platform: time
  condition:
    value_template: "{{ (state_attr('frigo_consomation', 'today_energy_kwh')|float) < float(0.6) }}"
  - data:
      message: problème consomation frigo trop faible
      title: verif frigo problème frigo consomation
    service: notify.flocknotification
thanks for answers
Why does the template use the float filter here:
< float(0.6)
when this is the same thing and involves one less conversion:
< 0.6
