Config check on 2022.9
I was looking to update my instance. I have a pipeline that runs and my test phase does a config check. I am getting this back.
Fatal error while loading config: 'issue_registry'
Failed config
  General Errors:
    - 'issue_registry'
I have no idea what that is, i have searched all my configs and see no reference at all to that. Anyone seen that before?
This is using the 2022.9 docker.
false alarm. there were some warning messages that infact were show stoppers with the config.
Maybe not so much a warning? lol
Have same issue
Me too
By(t)e
So the answer here is that your config probably has some warnings. Go to you HA > Settings to review if. you have any pending warnings. In my case it was the (soon to be) deprecated MQTT syntax I used on some of my entities.
