Config check result is confusing
I’m getting this result form config check:
log:
        variable.notify_device_joerg: [source /tmp/config/customize.yaml:146]
          icon: mdi:cellphone-message
        variable.notify_device_yvonne: [source /tmp/config/customize.yaml:144]
        variable.person_count_home: [source /tmp/config/customize.yaml:21]
          editable: True
          friendly_name: Personen anwesend
          icon: mdi:account-multiple
        variable.washing_mode: [source /tmp/config/customize.yaml:15]
          friendly_name: Waschmaschine
          icon: mdi:washing-machine
        variable.who_is_first: [source /tmp/config/customize.yaml:138]
          friendly_name: Wer wird benachrichtigt
      elevation: 45
      latitude: Geo
      longitude: Geo
      time_zone: Europe/Berlin
      unit_system: metric
      whitelist_external_dirs: [source /tmp/config/configuration.yaml:9]
        - /config
        - /share
Successful config (partial)
  homeassistant:
The customizings list is even longer in the log.
What is the intension of that log?
Is there any todo for me?
Yes there is a problem as the config was only partially successful. However you have cut off the actual error so it’s impossible to say what the problem is.
I did not cut off something.
There is no more info in the log available.
Just the list of customizing entries is longer but always the same content.
There should be timestamps against each log entry.
That’s how the log looks like:
Log
          friendly_name: nach Köln
        sensor.outside_rain: [source /tmp/config/customize.yaml:81]
          icon: mdi:weather-rainy
        sensor.owm_condition: [source /tmp/config/customize.yaml:148]
          friendly_name: Bedingung
        sensor.owm_forecast: [source /tmp/config/customize.yaml:150]
          friendly_name: Demnächst
        sensor.upstairs_light_level: [source /tmp/config/customize.yaml:109]
          friendly_name: Helligkeit Treppe oben
          icon: mdi:weather-sunny
        sensor.yr_forecast_precipitation: [source /tmp/config/customize.yaml:91]
          friendly_name: YR Regen 3Std
        sensor.yr_forecast_symbol: [source /tmp/config/customize.yaml:83]
          friendly_name: YR Wetter 3Std
        sensor.yr_forecast_temperature: [source /tmp/config/customize.yaml:97]
          friendly_name: YR Temperatur 3Std
          icon: mdi:thermometer-lines
        sensor.yr_forecast_wind_speed: [source /tmp/config/customize.yaml:103]
          friendly_name: YR Wind 3Std
          icon: mdi:weather-windy
        sensor.yr_humidity: [source /tmp/config/customize.yaml:85]
          friendly_name: YR Luftfeuchtigkeit
          icon: mdi:water-percent
        sensor.yr_precipitation: [source /tmp/config/customize.yaml:88]
        sensor.yr_pressure: [source /tmp/config/customize.yaml:106]
          friendly_name: YR Luftdruck
          icon: mdi:gauge
        sensor.yr_symbol: [source /tmp/config/customize.yaml:152]
          friendly_name: Wetter
        sensor.yr_temperature: [source /tmp/config/customize.yaml:94]
        sensor.yr_wind_speed: [source /tmp/config/customize.yaml:100]
        sensor.yvonnes_location: [source /tmp/config/customize.yaml:69]
          entity_picture: /local/images/AvatarYS_modified.png
          friendly_name: Yvonne
        variable.active_scene_gz: [source /tmp/config/customize.yaml:130]
          icon: mdi:lightbulb
        variable.active_scene_sz: [source /tmp/config/customize.yaml:134]
          icon: mdi:lightbulb
        variable.active_scene_wz: [source /tmp/config/customize.yaml:132]
          icon: mdi:lightbulb
        variable.daylight_lx: [source /tmp/config/customize.yaml:124]
          icon: mdi:white-balance-sunny
        variable.dryer_mode: [source /tmp/config/customize.yaml:18]
          friendly_name: Trockner
        variable.familiy_leaving_home: [source /tmp/config/customize.yaml:136]
        variable.housewife_present: [source /tmp/config/customize.yaml:11]
          editable: True
          entity_picture: /local/images/AvatarDemet.png
          friendly_name: Demet
        variable.humidifier_set: [source /tmp/config/customize.yaml:128]
        variable.last_camera_refresh: [source /tmp/config/customize.yaml:141]
          friendly_name: Letztes Bild
          icon: mdi:camera-retake
        variable.last_general_motion_detected: [source /tmp/config/customize.yaml:121]
          friendly_name: Letzte Bewegung
          icon: mdi:motion-sensor
        variable.last_motion_detected_tr: [source /tmp/config/customize.yaml:118]
          friendly_name: Letzte Bew. Treppe
        variable.last_motion_detected_wz: [source /tmp/config/customize.yaml:115]
          friendly_name: Letzte Bew. Wohnzimmer
        variable.night_lx: [source /tmp/config/customize.yaml:126]
          icon: mdi:power-sleep
          editable: True
      elevation: 45
      latitude: Geo
      longitude: Geo
      unit_system: metric
        - /config
        - /share
  homeassistant:
that’s not the ‘log’, those are results of the config checker. The actual log is located in the config folder named homeassistant.log. It will have the errors you seek.
This one is empty.
I only have some warnings when starting HA regarding starting lasts longer then 10 seconds and
some components. That’s it.
My complete configuration works in 0.95.4
PS: There was an entry in the config check regarding netatmo before. I solved that meanwhile as well as here_custom_component.
I’d like to push my issue again.
I’m still having definately no idea, what’s going wrong with my customization.
I’ve checked everything and have no issues in my logfile.
But I still get these check results when I check my 0.95.4 vs. 0.96.5
Can anybody point me into the right direction?
FYI, responding to a thread doesn’t notify anyone in the thread that you responded. Responding and tagging people or using the reply button on a message will give a notification (instead of Blue reply button at bottom).
Anyways, on to your issue. Post your configuration. You’re having a partial configuration load so something is wrong in your configuration. The error appears to be occuring beyond line 150 in your homeassistant section, most likely in your customization section. So please post your entire homeassistant section including the customization section.
Make sure you reply tagging me or using this reply button.
Hi Petro,
thanks :slight_smile:
Enclosed my config:
homeassistant:
  latitude: xx.xxxxxx
  longitude: x.xxxxx
  elevation: 45
  unit_system: metric
  - /config
  - /share
  customize: !include customize.yaml
  auth_providers:
    - type: homeassistant
    - type: trusted_networks
      trusted_networks:
        - 192.168.178.0/24
        - 46.88.232.0/24
        - 79.240.7.0/24
        - 127.0.0.1
The customize.yaml:
person.jorg:
  entity_picture: /local/images/AvatarJN.png
person.yvonne:
person.chiara:
  entity_picture: /local/images/AvatarChiara.png
person.niklas:
  entity_picture: /local/images/AvatarNiklas.png
group.familie:
  entity_picture: /local/images/Avatar_Familie.png
media_player.kuche:
  icon: mdi:amazon
media_player.wohnzimmer:
  icon: mdi:amazon
media_player.gastezimmer:
  icon: mdi:amazon
media_player.schlafzimmer:
  icon: mdi:amazon
media_player.joerg_s_alexa_apps:
  icon: mdi:amazon
media_player.this_device:
  icon: mdi:amazon
media_player.pirol62_s_fire_tv:
  icon: mdi:amazon
binary_sensor.motion_motion_wohnzimmer:
  friendly_name: 'Bewegung Wohnzimmer'
binary_sensor.motion_treppe_motion_oben:
  friendly_name: 'Bewegung Treppe oben'
binary_sensor.motion_treppe_motion_unten:
  friendly_name: 'Bewegung Treppe unten'
binary_sensor.motion_motion_schlafzimmer:
  friendly_name: 'Bewegung Schlafzimmer'
binary_sensor.blink_eingang_motion_detected:
  friendly_name: 'Bewegung Eingang'
binary_sensor.blink_garten_motion_detected:
  friendly_name: 'Bewegung Garten'
binary_sensor.workday_sensor:
  friendly_name: 'Arbeitstag'
input_boolean.holiday_mode:
  icon: mdi:pool
input_boolean.joerg_stays_at_home:
  icon: mdi:home-heart
input_boolean.guest_mode:
  icon: mdi:glass-cocktail
input_boolean.yvonne_stays_at_home:
sensor.active_harmony_scene:
  icon: mdi:monitor-cellphone-star
  entity_picture: /local/images/Wohnzimmer_TV_small.png
sensor.joergs_location:
  friendly_name: 'Jörg'
  friendly_name: 'Yvonne'
sensor.bedroom_light_level:
  friendly_name: 'Helligkeit Schlafzimmer'
sensor.livingroom_light_level:
  friendly_name: 'Helligkeit Wohnzimmer'
sensor.downstairs_light_level:
  friendly_name: 'Helligkeit Treppe unten'
  friendly_name: 'YR Wetter 3Std'
sensor.yr_humidity:
  friendly_name: 'YR Luftfeuchtigkeit'
  friendly_name: 'YR Regen'
  friendly_name: 'YR Regen 3Std'
  friendly_name: 'YR Temperatur'
  friendly_name: 'YR Temperatur 3Std'
  friendly_name: 'YR Wind'
  friendly_name: 'YR Wind 3Std'
sensor.yr_pressure:
  icon: mdi:gauge
  friendly_name: 'YR Luftdruck'
  friendly_name: 'Helligkeit Treppe oben'
sensor.homematic_lichtsensor_aussen_illuminance:
  friendly_name: 'Helligkeit außen'
sensor.yr_symbol:
  friendly_name: 'Wetter'
sensor.meerbusch_osterath_to_dusseldorf_hbf:
  friendly_name: 'nach Düsseldorf'
sensor.meerbusch_osterath_to_koln_hbf:
  friendly_name: 'nach Köln'
  friendly_name: 'Letzte Bew. Wohnzimmer'
  friendly_name: 'Letzte Bew. Treppe'
  friendly_name: 'Letzte Bewegung'
variable.night_lx:
  icon: mdi:lightbulb
  icon: mdi:lightbulb
  icon: mdi:lightbulb
  friendly_name: 'Wer wird benachrichtigt'
  friendly_name: 'Letztes Bild'
  editable: true
  friendly_name: 'Demet'
  friendly_name: 'Waschmaschine'
  friendly_name: 'Trockner'
  editable: true
  friendly_name: 'Personen anwesend'
Looks like something with your auth_providers. To me, your configuration looks correct based on the documentation. I’m not familiar with auth providers so that’s about the extent of the help I can provide.
Thanks a lot. I will check.
regards
This whole thread is painfully confusing because it seems to be fraught with people asking for information from the OP and the OP not providing the information that was asked for.
Case in point, I don’t think that is your entire configuration. It’s only the “homeassistant:” section of the configuration.yaml file.
What does your entire configuration.yaml file look like?
I assume you are doing the “config check” by going to the “configuration” in the left side menu then clicking “general” then clicking the “check config” button, correct?
After you do that then what is the entire contents of the homeassistant.log file that is located in the same folder as your configuration.yaml file?
As far as I can see the “auth_providers:” seems to be OK.
If you think that the customize section is the culprit then you can verify that is the case by commenting out that line in your config and re-doing the check.
#customize: !include customize.yaml
What are the results of that?
While I tend to agree with this, both of his errors call out the home assistant section, which is why I only asked for the home assistant section.
EDIT: But now that I think about it, you could be very right. The config parser will output the keys in alphabetical order. This would put the auth_providers at the top of the config checker output, which could be truncated! Meaning the lines directly after his home assistant section are probably the cause of the issues. Good catch.
understood.
Now my complete config:
homeassistant:
  latitude: coordinate
  longitude: coordinate
  elevation: 45
  unit_system: metric
  - /config
  - /share
  auth_providers:
      trusted_networks:
        - 192.168.178.0/24
        - 46.88.232.0/24
        - 79.240.7.0/24
        - 127.0.0.1
alexa_media:
  accounts:
    - email: !secret alexa_email
      password: !secret alexa_password
      url: amazon.de
blink:
  username: !secret jy_login
  password: !secret jy_password
  scan_interval: 60
  binary_sensors:
    monitored_conditions:
      - motion_enabled
      - motion_detected
  sensors:
      - battery
      - wifi_strength
binary_sensor:
  - platform: huesensor
  - platform: workday
    country: DE
    province: NW
  - platform: ping
    host: 8.8.8.8
cloud:
  alexa:
    filter:
      exclude_domains:
        - light
        - automation
        - sensor
        - binary_sensor
        - media_player
        - group
        - cover
        - remote
        - climate
      include_entities:
        - script.command_bright_light
        - script.command_dim_light
        - script.command_halogen_light
        - script.command_tv_light
        - script.activate_cameras
        - script.deactivate_cameras
        - input_boolean.whereisjoerg
        - input_boolean.howlongwashing
        - input_boolean.holiday_mode
        - input_boolean.yvonnes_driving_time
        - input_boolean.light_permanent_off
        - input_boolean.guest_mode
        - switch.toggle
        - script.szene_good_night
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
device_tracker:
  - platform: fritz
    host: 192.168.178.1
    username: !secret fritz_user
    password: !secret fritz_pw
    interval_seconds: 45
    consider_home: 120
    new_device_defaults:
      track_new_devices: false
      hide_if_away: false
discovery:
  ignore:
    - sonos
    - samsung_tv
frontend:
  themes: !include_dir_merge_named themes
group: !include groups.yaml
hacs:
  token: token
http:
  base_url: https://my_token.ui.nabu.casa
  ssl_certificate: /ssl/fullchain.pem
  ssl_key: /ssl/privkey.pem
ifttt:
  key: !secret ifttt_key
input_boolean: !include input_boolean.yaml
input_select: !include input_select.yaml
logbook: !include logbook.yaml
logger:
  default: critical
netatmo:
  api_key: "api_key"
  secret_key: "secret_key"
  username: !secret na_user
  password: !secret na_pw
  discovery: true
notify:
  - name: "Pushover"
    platform: pushover
    api_key: "api_key"
    user_key: "user_key"
  - name: "command"
    platform: command_line
    command: "espeak -vmb/mb-us1"
  - platform: alexa_media
  - platform: file
    filename: /share/history/washer_stats.csv
    timestamp: false
panel_iframe:
  mdiindex:
    title: MDI Icon Index
    icon: mdi:vector-square
    url: https://cdn.rawgit.com/james-fry/home-assistant-mdi/efd95d7a/home-assistant-mdi.html
recorder: !include recorder.yaml
remote:
  - platform: harmony
    host: 192.168.178.55
speedtestdotnet:
  scan_interval:
    hours: 2
    - ping
    - download
    - upload
script: !include scripts.yaml
sensor: !include sensors.yaml
shell_command: !include shell_commands.yaml
switch: !include switches.yaml
tts:
  - platform: google_translate
    service_name: google_say
timer: !include timer.yaml
updater:
variable: !include variables.yaml
weather:
  - platform: openweathermap
    api_key: api_key
zone: !include zone.yaml
I have no errors in the logfile after restarting.
Just some warnings.
The configuration check provides “ok”
All components and automations are running as expected
What changed that caused it to now work?
I have definately no idea.
Well, isn’t that frustrating…
That’s typically not how things work, especially when you are getting errors due to a configuration mistake. Those typically don’t (never…?) just fix themselves.
But it’s good that it’s working.
Ok, I already opened an issue .
Thanks for your support
What was the issue you opened?
If you don’t know what fixed it how do you know what to report?
