Hi, I’m currently making a check on the config before I make and upgrade in the version. Currently, I’m using Home Assistant Core 0.103.2 and looking at updating it to 0.106.5.
However, when I made a check, the config check gave me a result of,
Successful config (partial)
google_assistant:
May I know what does that mean?
Will my google assistant fail to work if I update it? Currently, I’m exposing some of the switches and equipment to google assistant, they are directly connect to HASSIO and not google home. For example xiaomi aqara switches. I did that in order fo my switches to be functional on google assistant app. So if this update will make it dysfunctional, then any advice to how I can fix this so I could update my core?
