When I try to use the Automations.yaml file I get following error.
Same code is working fine in the configuration.yaml file.
I can not found the error does anyone know what the problem is?
ERROR
INFO:homeassistant.util.package:Attempting install of colorlog==3.1.4
Testing configuration at /config
ERROR:homeassistant.util.yaml:while parsing a flow node
expected the node content, but found ‘-’
in “/config/automations.yaml”, line 8, column 3
Failed config
General Errors:
- Error loading /config/configuration.yaml: while parsing a flow node
Successful config (partial)
Automations.yaml:
# Automation #
# Send notification when sun rises and sets with the Pushbullet
- alias: 'Send notification when sun rises'
platform: sun
event: sunrise
offset: '+00:00:00'
service: notify.pushbullet
message: 'The sun is up.'
- alias: 'Send notification when sun sets'
platform: sun
event: sunset
offset: '+00:00:00'
message: 'The sun is down.'
