I guess you see only a very helpful “configuration error” message instead of the error itself since recent changes.
Suggest to reduce the card to the minimum to get a working result, then increase a complexity step by step.
Note that this is a custom card which may be used by many people. Means - you may not get a quick answer.
Btw, are you using a yaml or a storage mode of a dashboard?
If a storage (with UI editor) - then did you take this code from the UI editor? Asking because your code starts with “-“.
Logger: frontend.js.modern.202507021
Source: components/system_log/init.py:331
First occurred: July 4, 2025 at 6:33:32 PM (98 occurrences)
Last logged: 9:07:42 AM
Uncaught error from Chrome WebView 137.0.7151.116 on Android 15 Error: Failed to execute ‘define’ on ‘CustomElementRegistry’: the name “focus-trap” has already been used with this registry A.define (src/scoped-custom-element-registry.ts:180:12) a.define (/hacsfiles/tabbed-card/tabbed-card.js:63:109) /hacsfiles/frigate-hass-card/card-f2dccb12.js:75:3686
Uncaught error from Chrome WebView 137.0.7151.116 on Android 15 Error: Failed to execute ‘define’ on ‘CustomElementRegistry’: the name “focus-trap” has already been used with this registry A.define (src/scoped-custom-element-registry.ts:180:12) a.define (/hacsfiles/tabbed-card/tabbed-card.js:63:109) /hacsfiles/advanced-camera-card/card-855fd26e.js:75:3686
Uncaught error from Chrome 138.0.0.0 on Windows 10 Error: Failed to execute ‘define’ on ‘CustomElementRegistry’: the name “focus-trap” has already been used with this registry A.define (src/scoped-custom-element-registry.ts:180:12) a.define (/hacsfiles/tabbed-card/tabbed-card.js:63:109) /hacsfiles/frigate-hass-card/card-f2dccb12.js:75:3686
Uncaught error from Chrome 138.0.0.0 on Windows 10 TypeError: Cannot set properties of undefined (setting ‘moment’) /local/moment.js:10:19 /local/moment.js:11:2
Uncaught error from Chrome 138.0.0.0 on Windows 10 Error: Failed to execute ‘define’ on ‘CustomElementRegistry’: the name “focus-trap” has already been used with this registry A.define (src/scoped-custom-element-registry.ts:180:12) a.define (/hacsfiles/tabbed-card/tabbed-card.js:63:109) /hacsfiles/advanced-camera-card/card-855fd26e.js:75:3686
Well that’s too bad it works like that… so apparently I need to figure out the config because well it’s not correct for some reason. Thank you for the tip!
