Hi
I have this message “Config error. See dev-info panel for details.” in a panel at the top of the screen?
Please could someone help me understand what it means, and what should I do ?
Kind Regards
Hi
Kind Regards
The developer tool buttons are at the bottom of the left-hand menu panel in Home Assistant’s UI. Choose the one with an I in a circle.
Alternately, home-assistant.log
in the same folder as your configuration YAML will contain the same info.
Thanks,
I was not able to get the log to load via the UI, but via SSH it seems all the space has been consumed by what I can only assume is the HASS logs file !!?
A reboot of my PI has reloaded everything and removed the error.
