I was trying to setup MQTT and Mosquitto, and after I fixed an error in configuration.yaml the frontend wouldn’t load.
So I just tried commenting out the MQTT stuff. But that didn’t seem to help
When I run hass --script check_config I get this response;
Testing configuration at /home/homeassistant/.homeassistant
2017-07-17 22:53:55 INFO (Thread-3) [homeassistant.config] Upgrading config directory from 0.48.1 to 0.49.0
Fatal error while loading config: [Errno 13] Permission denied: __init__.py
Failed config
General Errors:
- [Errno 13] Permission denied: '__init__.py'
Successful config (partial)
The log only shows some warnings about components that takes over 10 sec. to load.
I’m all new to HA, so any help would be appreciated.
Could you please provide some background information about what platform your HASS instance is running on, which OS and installation method you used and so on.
