G’day I’m slowly working my way through this amazing software. How is this free! so rad. I have some errors showing up that I have been unable to google, I was wondering if anyone can shed some light on them for me.
17-04-22 20:11:08 ERROR (MainThread) [aiohttp.server] Error handling request
File "/Users/Dom/.homeassistant/deps/aiohttp/connector.py", line 655, in _create_direct_connection
local_addr=self._local_addr)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/base_events.py", line 802, in create_connection
sock, protocol_factory, ssl, server_hostname)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/base_events.py", line 828, in _create_connection_transport
yield from waiter
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/sslproto.py", line 503, in data_received
ssldata, appdata = self._sslpipe.feed_ssldata(data)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/sslproto.py", line 201, in feed_ssldata
self._sslobj.do_handshake()
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/ssl.py", line 683, in do_handshake
ssl.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:749)
File "/Users/Dom/.homeassistant/deps/aiohttp/connector.py", line 375, in connect
proto = yield from self._create_connection(req)
File "/Users/Dom/.homeassistant/deps/aiohttp/connector.py", line 632, in _create_connection
_, proto = yield from self._create_direct_connection(req)
File "/Users/Dom/.homeassistant/deps/aiohttp/connector.py", line 682, in _create_direct_connection
(req.host, req.port, exc.strerror)) from exc
aiohttp.client_exceptions.ClientConnectorError: [Errno 1] Can not connect to cloud.githubusercontent.com:443 [[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:749)]
