Hya,
when trying to add an integration, i get the following error message:
Config flow could not be loaded: 500 Internal Server Error Server got itself in trouble
Any clue?
Hya,
Any clue?
Same. No clue
any solution to this error?
Nope. Followed all I can. Amazed how few reply on this forum
I have the issue too.
Same issue here, I was trying to add Frigate.
Same here, in my case I was trying to add Tapo Camera Control from HACS.
My idea was to try frigate next, I hope it worksā¦
Show the HA logs when adding Tapo Camera Control, without logs impossible to help.
Registrador: homeassistant.util.logging
Fuente: util/logging.py:103
Ocurrió por primera vez: 17:56:24 (1 ocurrencias)
Ćltimo inicio de sesión: 17:56:24
Exception in async_forward_config_entry_changes when dispatching 'SignalType(name='config_entry_changed')': (<ConfigEntryChange.REMOVED: 'removed'>, <ConfigEntry entry_id=7110bb19ab5d0bfb200c50ca96a51e8f version=1 domain=auto_backup title=Auto Backup state=ConfigEntryState.NOT_LOADED unique_id=None>) Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 517, in async_forward_config_entry_changes integration = async_get_loaded_integration(hass, entry.domain) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/src/homeassistant/homeassistant/loader.py", line 1314, in async_get_loaded_integration raise IntegrationNotLoaded(domain) homeassistant.loader.IntegrationNotLoaded: Integration 'auto_backup' not loaded.
Registrador: homeassistant.util.package
Fuente: util/package.py:123
Ocurrió por primera vez: 17:56:38 (3 ocurrencias)
Ćltimo inicio de sesión: 17:56:44
Unable to install package pytapo==3.3.19: ERROR: Exception: Traceback (most recent call last): File "/config/lsiopy/lib/python3.11/site-packages/pip/_internal/cli/base_command.py", line 167, in exc_logging_wrapper status = run_func(*args) ^^^^^^^^^^^^^^^ File "/config/lsiopy/lib/python3.11/site-packages/pip/_internal/cli/req_command.py", line 205, in wrapper return func(self, options, args) ^^^^^^^^^^^^^^^^^^^^^^^^^ File "/config/lsiopy/lib/python3.11/site-packages/pip/_internal/commands/install.py", line 285, in run session = self.get_default_session(options) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/config/lsiopy/lib/python3.11/site-packages/pip/_internal/cli/req_command.py", line 75, in get_default_session self._session = self.enter_context(self._build_session(options)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/config/lsiopy/lib/python3.11/site-packages/pip/_internal/cli/req_command.py", line 89, in _build_session session = PipSession( ^^^^^^^^^^^ File "/config/lsiopy/lib/python3.11/site-packages/pip/_internal/network/session.py", line 282, in __init__ self.headers["User-Agent"] = user_agent() ^^^^^^^^^^^^ File "/config/lsiopy/lib/python3.11/site-packages/pip/_internal/network/session.py", line 157, in user_agent setuptools_dist = get_default_environment().get_distribution("setuptools") ^^^^^^^^^^^^^^^^^^^^^^^^^ File "/config/lsiopy/lib/python3.11/site-packages/pip/_internal/metadata/__init__.py", line 24, in get_default_environment from .pkg_resources import Environment File "/config/lsiopy/lib/python3.11/site-packages/pip/_internal/metadata/pkg_resources.py", line 9, in <module> from pip._vendor import pkg_resources File "/config/lsiopy/lib/python3.11/site-packages/pip/_vendor/pkg_resources/__init__.py", line 2164, in <module> register_finder(pkgutil.ImpImporter, find_on_path) ^^^^^^^^^^^^^^^^^^^ AttributeError: module 'pkgutil' has no attribute 'ImpImporter'. Did you mean: 'zipimporter'?
Registrador: aiohttp.server
Fuente: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:421
Ocurrió por primera vez: 17:56:44 (1 ocurrencias)
Error handling request
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 88, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 71, in with_admin
return await func(self, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 73, in wrapper
result = await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 172, in post
return await self._post_impl(request, data)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 179, in _post_impl
return await super()._post_impl(request, data)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 84, in _post_impl
result = await self._flow_mgr.async_init(
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1155, in async_init
flow, result = await self._async_init(flow_id, handler, context, data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1175, in _async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1312, in async_create_flow
handler = await _async_get_flow_handler(
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2608, in _async_get_flow_handler
await _load_integration(hass, domain, hass_config)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2585, in _load_integration
await async_process_deps_reqs(hass, hass_config, integration)
File "/usr/src/homeassistant/homeassistant/setup.py", line 551, in async_process_deps_reqs
await requirements.async_get_integration_with_requirements(
File "/usr/src/homeassistant/homeassistant/requirements.py", line 53, in async_get_integration_with_requirements
return await manager.async_get_integration_with_requirements(domain)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 176, in async_get_integration_with_requirements
await self._async_process_integration(integration, done)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 193, in _async_process_integration
await self.async_process_requirements(
File "/usr/src/homeassistant/homeassistant/requirements.py", line 280, in async_process_requirements
await self._async_process_requirements(name, missing)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 318, in _async_process_requirements
raise RequirementsNotFound(name, list(failures))
homeassistant.requirements.RequirementsNotFound: Requirements for tapo_control not found: ['pytapo==3.3.19'].
Sorry theyāre a bit long, those a the 3 errors that appear in the log.
I saw people suggesting looking into the .storage folder, but I didnāt see anyone trying to install Tapo Control specificallyā¦
Thanks!
What version of HA are you running ?
Core
2024.4.0
Frontend
20240403.1
Inside a docker container through CasaOS
