Config flow could not be loaded: {"message":"Invalid handler specified"}
Hello All,
i’m new member interested to use HA. i didn install it successfully on (Sooff iHost) via Docker & the visrion of HA as following:
Core 2024.1.3
Frontend 20240104.0
i trired to follow the following steps in this video : https://www.youtube.com/watch?v=OhugPsohwjE
the installation worked well and HA worked but Unfortunately following couldn’t find or installed:
1- HA Add-ons is not available
2- Couldn’t install the HA supervisor
3- failed to install the HACs , and i get the following error “Config flow could not be loaded: {“message”:“Invalid handler specified”}”
hope to find a solution and have : the add-on , and also use supervisor on the iHost.
Any idea pls
Up up up pls help
Hi did you work it out I have same message. I am also a beginner trying to install HACS. It is in the home assistant so have downloaded but nothing. Quite frustrating
Cheers Andy Scotland
follow these instructions for your HA installation method
Hi Francis
I am running the latest home assistant software and have followed
These instructions. HACS appears in my custom components. I have tried restarting and making sure browsers are clear. Do you have anything else I can try
And you still get that error when adding the integration ?
Yes I still get that message. Tried reinstalling after renaming old Hacs but still no luck.
Cheers
You have something like this ?
The only thing in components is HACS
And within it has _init_py
Base.py
config_flow.py
Const.py
Data_client.py
Diagnostics.py
Entity.py
