Config Flow - Issue updating configuration
Hi, creating and editing a config is working nicely, however, I’m getting an error.
2024-12-18 12:30:14.824 DEBUG (MainThread) [custom_components.afvalwijzer.config_flow] Config entry: <ConfigEntry entry_id=01JFCJRQJQKH3JCPJ57N9DPTWZ version=1 domain=afvalwijzer title=Afvalwijzer state=ConfigEntryState.LOADED unique_id=None>
2024-12-18 12:30:16.569 DEBUG (MainThread) [custom_components.afvalwijzer.config_flow] Config entry: <ConfigEntry entry_id=01JFCJRQJQKH3JCPJ57N9DPTWZ version=1 domain=afvalwijzer title=Afvalwijzer state=ConfigEntryState.LOADED unique_id=None>
2024-12-18 12:30:16.569 DEBUG (MainThread) [custom_components.afvalwijzer.config_flow] Updated options: {'date_isoformat': False, 'default_label': 'Geen', 'exclude_list': '', 'exclude_pickup_today': True, 'postal_code': '5146EA', 'provider': 'mijnafvalwijzer', 'street_number': '1', 'suffix': ''}
2024-12-18 12:30:16.569 DEBUG (MainThread) [custom_components.afvalwijzer.config_flow] Attempting to update config entry with options: {'date_isoformat': False, 'default_label': 'Geen', 'exclude_list': '', 'exclude_pickup_today': True, 'postal_code': '5146EA', 'provider': 'mijnafvalwijzer', 'street_number': '73', 'suffix': ''}
2024-12-18 12:30:16.569 ERROR (MainThread) [custom_components.afvalwijzer.config_flow] Error updating config entry: object bool can't be used in 'await' expression
Code:
import voluptuous as vol
from homeassistant import config_entries
from homeassistant.core import callback
from homeassistant.helpers import config_validation as cv
import logging
from .const.const import (
    DOMAIN,
    CONF_COLLECTOR,
    CONF_POSTAL_CODE,
    CONF_STREET_NUMBER,
    CONF_SUFFIX,
    CONF_EXCLUDE_PICKUP_TODAY,
    CONF_DATE_ISOFORMAT,
    CONF_DEFAULT_LABEL,
    CONF_EXCLUDE_LIST,
DATA_SCHEMA = vol.Schema({
    vol.Required(CONF_COLLECTOR): cv.string,
    vol.Required(CONF_POSTAL_CODE): cv.string,
    vol.Required(CONF_STREET_NUMBER): cv.string,
    vol.Optional(CONF_SUFFIX, default=""): cv.string,
    vol.Optional(CONF_EXCLUDE_PICKUP_TODAY, default=True): cv.boolean,
    vol.Optional(CONF_DATE_ISOFORMAT, default=False): cv.boolean,
    vol.Optional(CONF_DEFAULT_LABEL, default="geen"): cv.string,
    vol.Optional(CONF_EXCLUDE_LIST, default=""): cv.string,
class AfvalwijzerConfigFlow(config_entries.ConfigFlow, domain=DOMAIN):
    """Handle a config flow for Afvalwijzer."""
    VERSION = 1
    async def async_step_user(self, user_input=None):
        """Handle the initial step."""
        errors = {}
        if user_input is not None:
            # Perform validation
            if not self._validate_postal_code(user_input.get(CONF_POSTAL_CODE)):
                errors["postal_code"] = "config.error.invalid_postal_code"
            elif not self._validate_street_number(user_input.get(CONF_STREET_NUMBER)):
                errors["street_number"] = "config.error.invalid_street_number"
            else:
                # Validation passed, create the entry
                return self.async_create_entry(title="Afvalwijzer", data=user_input)
        return self.async_show_form(
            step_id="user",
            data_schema=DATA_SCHEMA,
            errors=errors,
            description_placeholders={
                "provider": "e.g., mijnafvalwijzer",
                "postal_code": "e.g., 1234AB",
    @staticmethod
    @callback
    def async_get_options_flow(config_entry):
        return AfvalwijzerOptionsFlow()
    def _validate_postal_code(self, postal_code):
        """Validate the postal code format."""
        return (
            isinstance(postal_code, str)
            and len(postal_code) == 6
            and postal_code[:4].isdigit()
            and postal_code[4:].isalpha()
    def _validate_street_number(self, street_number):
        """Validate the street number."""
        return street_number.isdigit()
class AfvalwijzerOptionsFlow(config_entries.OptionsFlow):
    """Handle options for Afvalwijzer."""
    async def async_step_init(self, user_input=None):
        """Handle options configuration."""
        _LOGGER = logging.getLogger(__name__)
        _LOGGER.debug(f"Config entry: {self.config_entry}")
        # Ensure self.config_entry is valid
        if not self.config_entry:
            _LOGGER.error("Config entry is invalid.")
            return self.async_abort(reason="invalid_config_entry")
        current_options = self.config_entry.options
            # Merge the user input with the current options
            updated_options = {**current_options, **user_input}
            # Ensure updated_options is a valid dictionary
            _LOGGER.debug(f"Updated options: {updated_options}")
            if not isinstance(updated_options, dict):
                _LOGGER.error("Updated options must be a dictionary.")
                return self.async_abort(reason="invalid_options")
            # Try to update the config entry with the options
            try:
                _LOGGER.debug(f"Attempting to update config entry with options: {updated_options}")
                await self.hass.config_entries.async_update_entry(
                    self.config_entry, options=updated_options
            except Exception as e:
                _LOGGER.error(f"Error updating config entry: {e}")
                return self.async_abort(reason="update_failed")
            # After updating, return to the main page or close the flow
            return self.async_create_entry(title="", data=updated_options)
        # Show the form with the existing values as defaults
        options_schema = vol.Schema({
            vol.Required(CONF_COLLECTOR, default=current_options.get(CONF_COLLECTOR, "")): cv.string,
            vol.Required(CONF_POSTAL_CODE, default=current_options.get(CONF_POSTAL_CODE, "")): cv.string,
            vol.Required(CONF_STREET_NUMBER, default=current_options.get(CONF_STREET_NUMBER, "")): cv.string,
            vol.Optional(CONF_SUFFIX, default=current_options.get(CONF_SUFFIX, "")): cv.string,
            vol.Optional(CONF_EXCLUDE_PICKUP_TODAY, default=current_options.get(CONF_EXCLUDE_PICKUP_TODAY, "")): cv.boolean,
            vol.Optional(CONF_DATE_ISOFORMAT, default=current_options.get(CONF_DATE_ISOFORMAT, "")): cv.boolean,
            vol.Optional(CONF_DEFAULT_LABEL, default=current_options.get(CONF_DEFAULT_LABEL, "")): cv.string,
            vol.Optional(CONF_EXCLUDE_LIST, default=current_options.get(CONF_EXCLUDE_LIST, "")): cv.string,
            step_id="init", data_schema=options_schema, errors={},
            description_placeholders={}
I’ve tried a lot on the boolean part. Maybe I’m missing something completely. The docs about config_flow are somewhat confusing to me to be honest (lack of knowledge I assume). Hope someone can help me out. Thanks.
Happy to share more info if needed. Repo / full code can be found here: GitHub - xirixiz/homeassistant-afvalwijzer: Provides sensors for some Dutch waste collectors
The update method isn’t async, drop the await from your code, it returns a value type bool.
@callback
def async_update_entry(
    self,
    entry: ConfigEntry,
) -> bool:
I’m pretty new to this too, been getting these kind of issues occasionally.
There are a few methods in homeassistant.config_entries.py that have an ‘async’ prefix but aren’t defined as async methods. It also calls a number of methods with ‘async’ prefix that are not async methods,check the return type.
So many bear traps for new players…
