I need some help/advice, as I dont know what to do next.
I have ComWinTop modbus temperature
RS485 parameters
Default slave ID: 1
Default baud rate: 9600,
8 data bits, 1 stop bit, none parity
My setup currently
- name: CWT temperature
type: serial
port: /dev/ttyACM0
baudrate: 9600
bytesize: 8
method: rtu
parity: N
stopbits: 1
sensors:
- name: varaaja_temperature
unique_id: varajaa_temp
slave: 1
address: 2001
input_type: input
unit_of_measurement: °C
state_class: measurement
scan_interval: 15
scale: 0.1
offset: 0
precision: 1
data_type: int16
Cant get data out, it also doesnt show up in entities.
sensors part must be incorrect, but i have no clue how to set it up.
I have other modbus device on same adapter in different port, that is working.
Edit. After full reboot entity showed up, but is unavailable.
